air cleaners best worst?
Re: air cleaners best worst?
Postby jet1 » Fri Jun 08, 2012 2:57 pm
This is what I have right now with a 3" x 14 element.
jet1
Postby MadBill » Fri Jun 08, 2012 7:30 pm
The lid should be fine. The base I'd say not the best; not the worst. Better than the spun designs I mentioned, but not as good as the smoother contour of the true L-88 (and others, such as Z-28) design. As mentioned, a 4" element is cheap insurance against restriction.
"There's no product that can't be made cheaper and worse."
Postby SchmidtMotorWorks » Fri Jun 08, 2012 8:18 pm
I don't think you will find much flow difference in any reasonable air cleaner but you will find difference in the performance that comes with cooler air if the air cleaner does not transfer heat to the air as fast (as aluminum does) and if the under-hood temp is high, ducting in cold air will make far more difference than air flow.
http://www.schmidtmotorworks.com CamFlowRPM software, CAD CAM CAE CFD, CNC Machining.
SchmidtMotorWorks
Postby gr9082 » Fri Jun 08, 2012 10:09 pm
Braswell filter is 4 to 8 HP over all filter I tested
gr9082
Postby rfoll » Fri Jun 08, 2012 10:48 pm
X2 on the cold air. GM saw fit to install it on cars from the '70s on. One of the local speed shops tested these against everything they had on hand, and they came out on top. They are only 14" and a Holley carb will need a small spacer. Nice smooth curve on the inside. If I rember, it's something like 1 percent more power for every 10 degrees you reduce the temp of the air feeding the carb.
rfoll
Postby MadBill » Sat Jun 09, 2012 8:01 am
In a post some years back, bigjoe said the dyno air turbine usually made more power than no or any air clearner! Myabe not the most practical choice though.. :-k
Postby Bob Hollinshead » Sat Jun 09, 2012 8:03 am
gr9082 wrote:Braswell filter is 4 to 8 HP over all filter I tested
I can't find a picture on Braswell's site, does anyone have photos of this filter assemby?
Pro question poster.
Bob Hollinshead
Postby MadBill » Sat Jun 09, 2012 10:17 am
Got one somewhere, I'll try to dig it up. The OD is tapered..
Postby justahoby » Sat Jun 09, 2012 1:58 pm
would them air cleaner lids that are also an air cleaner themselves help? or is it just a gimic? seems like it would bypass this problem, jst curious if was tested. Does it get affected too by how close it is to the hood..
Student. TSTC, Waco, TX
justahoby
Postby MadBill » Sat Jun 09, 2012 3:29 pm
I think the only place the K&N Extreme filter lid would help would be if there wasn't room for an adequate height normal filter.
There are numerous reports of substantial power loss when using them with taller units. Some say it's because "carbs are designed for air to flow in from the sides." and they don't work when fed from above, but of course that's exactly how an air turbine feeds the engine on the dyno. I suspect it's the turbulence that ensues when the lateral flow from the normal filter encounters the vertical flow from the lid...
PS: Here's a shot of a Roush carbon fiber box for a 16" filter, modified to fit a spread bore Braswell. note the smooth contours..
Postby justahoby » Sat Jun 09, 2012 5:15 pm
it seems like a crazy idea carbs a designed to breathe from the side to me also lol, but i would agree a taller filter may be better. Those xtreem lids are pleated, they are above your carb at different angles creating odd turbulence when the carb would like to pull down... so would a large filter, regular shaped,easy breathing, that lets in air through much surface area around, create a well fed low turbulence area , of air available for the the carb to draw in... kinda like a large plenum of air above the carburetor.. maybe i am over thinking this... :lol: ... but if so i got a lot of room under my 69 c10 to just go with a tall filter.. Real tall.. :mrgreen:
justahoby
Postby RCJ » Sat Jun 09, 2012 6:56 pm
I have always wondered if you had a radius on the lower half then on the lid if the radius started the same but decreased.Basically a venturi above the carb would this create more power.
RCJ
Postby af2 » Sat Jun 09, 2012 6:56 pm
Bill, I feel the one I use is pretty good. 16"
GURU is only a name.
af2
Postby MadBill » Sat Jun 09, 2012 7:49 pm
I'd think that unit would cause some restriction.... at about the 2500 HP level! =D>
Postby Vintrcr » Sat Jun 09, 2012 7:53 pm
Just for reference here is a factory 1969 Z/28 base. (open element-non cowl)
Vintrcr
PreviousNext
Return to Engine Tech
Who is online
Users browsing this forum: 5speed1966, Bing [Bot], Birdlab, Calypso, Exabot [Bot], Ron Clevenger, treyrags and 28 guests
