Cam dynamics sbc solid roller id help
Postby c4mo » Wed Jun 06, 2012 7:49 am
I have cd solid roller for a sbc. That has No cam card. I know the cam is from the 70s and was In a ss/ma 327 250 hP. The numbers on the cam are 316 over 316, r over a, and the number 12602. Thanks
Morgan Allen
c4mo
Re: Cam dynamics sbc solid roller id help
Postby cknight » Fri Jun 08, 2012 7:39 am
This is a single pattern roller camshaft. The duration at .050" is 280 degrees. Lobe lift is .420", resulting in a gross valve lift of .630" with the standard 1.5:1 rocker arm ratio. Recommended valve lash is .030" at operating temperature. Lobe separation is 104 degrees. Cam timing at .050" is: intake opens 38 degrees BTDC, intake closes 62 degrees ABDC, exhaust opens 66 degrees BBDC, exhaust closes 34 degrees ATDC. Regards, Chase
cknight
Postby c4mo » Fri Jun 08, 2012 12:13 pm
Thanks!
Morgan Allen
c4mo
Return to Engine Tech
Who is online
Users browsing this forum: 340king, 900HP, 95GTSpeedDemon, Bing [Bot], Challenger73, Eliminator540, Exabot [Bot], JerseyDevil, JohnnyB, jscamaro1, k-star, krayn, Majestic-12 [Bot], nxtruck, PFC1 and 28 guests
