Having some trouble with my dirt track car .350 chevy ,flat top pistons ,angel milled vortecs ,solid cam,1 5/8 headers ,around 500hp at 6500,
Runs great in the heat races but after about 15 laps, doesn't matter if they are under green or yellow,the engine starts missing under full power.Have done a compression test and leak down both showed good ,checked all valve springs,Lash has not changed any on the shaft rockers.Plugs show a little lean went up one jet size in all 4 corners, didn't help.The ignition is a mallory 6al with a mallory 30440 e core coil,.These part were new but purchased for a different project,I've never used a coil like it on a dirt track car.On a 16 volt battery also.Is it possible for the coil to heat soak after a period of time and produce to much resistance and the voltage drop to low to fire the plugs?
