I was always told if you have a good ignition, the bigger the plug gap the better. I have mine set at .050 which is what my ignition instructions said to use. I have a 10.7to1 aluminum headed 496bbc with hyd roller and performance dist HEI and run 93 octane fuel. The engine runs good and never misses a beat but I have been lurking on some other forums and read these big gaps are not necessary. Here is what I read from another forum. I have alot of faith in what this person says and feel he is correct but all I have ever read before is the bigger the gap the better. What do you guys feel is correct in your opinion?
I am a huge advocate of not running large gaps in perfromance deals
They do nothing except,,,
They will tend to fire a very lean mixture which is harder to get started
GM ran large gaps for one sole purpose
To fire stupid lean mixtures in low compression engines that were far from efficient & had very little cylinder pressure compared to a performance engine.
In my opinion wide gaps have no place in a higher compression performance oriented engine & are a misfire waiting to happen as cylinder pressures go up.
I have never seen any power in the .045+ gaps recommended by some
I have never seen any loss of power at .030-.035
A Vertex mag uses .020 & less with no issues in some pretty stout deals
This whole wide gap idea is again in my opinion another example of monkey see, monkey do... print it in enough magazines it must be true crap
It has it's place but I do not feel this place is in performance engines.
Here is another quote that I found about the small gap theory.
Voltage rating (KV) of the coil is what the coil is capable of, not what it fires each strike.
Voltage requirements rise from, heat... pressure... and gap
Increase any of the 3 variables and the KV required to fire increases.
An engine at a 150 BMEP load requires about 20 to 22 KV to fire a .025 gold-palladium gap versus same engine at .015 gap takes about 15 KV. I know this from systems I have worked on at work, not play. With real-time firing KV on display.
My engine theoretically sees 216BMEP. I figger .025 gap is all the risk of misfire I want at 8000rpm and 216BMEP. Hard to alter the heat, and the pressure is what we are after, therefore gap is all I can really control.
Just me
