Cam after 3 years of 150 lbs spring. Street, autocross, track.
I rebuilt the top end. Same head 6 valves. New rockers & lifters. Springs uprated to 187lbs on the seat. After this I ran 1 year with more track use than ever. Then I ran it dry in the corners at the track and took engine apart with damage...Although not to the top end.
The images might not tell you much. It seems to me that after running a year with 25% uprated valve spring, some of the previous discoloration has gone. Maybe due to the lifter following the lobe more closely?
I've been looking out for pit- formation on the closing side of the lobes, but have found no real alarming marks. Although... Here's a lobe with something maybe going on...
I'm not by any means an expert. Hopefully some more experienced builders and cam techs will comment.
Regards
RS
