Flatmilling EQ IMCA spec head
Postby dln383 » Sat Apr 28, 2012 4:48 pm
How much can I flatmill this head and still get the intake to fit properly. You guys already know this but it has to be no more than 10.5 to 1 . Gonna do one of the 500 cfm flat top engines for stockcar and could use some advise. I read that .085 mill would get ya about 61cc chamber but I don't have a clue. Thanks guys
dln383
Re: Flatmilling EQ IMCA spec head
Postby dirtracr5 » Sat Apr 28, 2012 5:07 pm
.080 will get you 62cc. if you dont zero deck the block (say 9.020) and get pistons with an added .020ch it will fit easy. .080 mill with a 9.000 it will fit but its not easy.
dirtracr5
Postby Brian W » Sun Apr 29, 2012 10:49 am
Make sure you check the CC's of each chamber. I have seen them off by 2cc'c on the same out of the box head. 0.0055 per CC is the removal rate on the IMCA spec head. If they are off you can usually angle the head slightly from end to end (#1 to #7 cyl) to correct the chamber size. Also, and I'm sure you already know this but the shape of the valves you choose can vary greatly the CC of the chamber.
Brian W
Postby dln383 » Sun Apr 29, 2012 3:07 pm
Appreciate you guys sharing the info. If I would mill .080 and deck at 9.020 would I have to use the .044 head gasket or would the .015 shim work ? My pistons are 1.560 CH so I'll be .020 down and a quench area of .064 with the composite gasket.
dln383
Postby Brian W » Sun Apr 29, 2012 3:20 pm
Assuming a 4.030 bore and a flat top piston volume of -5cc. You could run a felpro 1094 .015 thick gasket and have .035 PTH clearance. Mill your head to 64cc and you will be @ 10.5 to 1. That will work but you are gonna have to check every cyl for deck height.
Brian W
Return to Engine Tech
Who is online
Users browsing this forum: Belgian1979, Bing [Bot], Matt Gruber, Yahoo [Bot] and 14 guests
