PackardV8 wrote:Very interesting and thanks for sharing.
Question - specifically what makes the Lucas, Valvoline et al Racing Oils not suitable for longer term street use?
jack vines
Cedarmachine wrote:I use O Riley generic oil in all our daily drivers and in my dually with Howard's Zinc additive. When it goes on sale for $2 a quart, I buy at least 6 cases. Honestly, I thought it probably was a good oil,but I bought it based on price. I may just start running this in some race engines as well, with an additive.
Great info, thanks for the effort.
jack vines
mod7 wrote:I was told by Valvoline that the difference between the non street legal oil and the VR-1 was that the Non street legal oil has no detergents, and if used for extended periods of time can build up more then standard detergent oil.
CREngines wrote:=D> i applaud your effort in performing this test.
We have had very positive results with the Lucas racing oil as well.
We didnt have much luck with the
Brad Penn and that lines up with what you found.
GM-DR wrote:Thanks for all your hard work!!!!!verrry interesting!!!!! Would Love to see some numbers on Joe Gibbs XP1, Rotella 15-40, and Rotella 5-40 synthetic? Did you find in general that synthetics outpeformed conventionals?
Blown BBC wrote:Very interesting, I guess I should have not switched from Valvoline VR1 to Brad Penn, although its hard to tell because I run 20w50 or straight 50 and you didn't test much of that weight. I would like to see the Valvoline VR1 in 20w50 and 50, Brad Penn in 20w50 and Amsoil in zrod 20w50. Any chance you can add those to your list? I will send you a Brad Penn 20w50 if you want. Thank you for the results.
n5ifi wrote:What does the test mean in a race motor?
What part of a motor would this test be applicable to?
How does that pressure from your test apply to an engine bearing which probably has more surface area than your test and is pressure fed?
Was your test made with oil on the suface of the metal alone or was it pressure fed?
I've been a "Bobs the oil guy" member for a while and seen so many test it would make your head spin.
I've run the best oils and I've run the worst oils in your test and never found any real difference in an motor oil based on this type of wear test.
I'm not saying it isn't true, I've just personally never seen it.
I'll give an example. I've got a buddy of mine that runs a solid lifter cam, 466, 12:1 compression and goes through the traps in the quarter at 7200. He runs Motorcraft 5-30 oil and has now for 7 years changing oil 1 time every year wether it's needed or not. Now his oil pan is 8 quarts so......
The motor has never been apart and has made hundreds of passes and that oil ranked low on your scale. I have another buddy that ran Royal Purple oil (not sure about the weight) and never changed it or the filter for over 5/6/7 years (he is a mechanic and own his own station). He finally ruined the motor by running it low on oil. His son checked it and didn't know what he was doing. That motor was never hurt and 5+ years on a racing motor is.....well good I would say. I have to hear him bragging about it all the time. We give him hell for ruining a perfectly good engine by running it out of oil. Both of these guys are bracket racers and race often and believe me do very little maintenance. These cars are never torn down during the off season and inspected and the valve springs are never even realsed during the winter. I do more than they do on their cars. I admit those were not the most demanding situatons but there was no roller cam in the bunch so there was metal parts making contact that wear not rollerized.
Your test if I remember right is a round piece of metal spinning and another piece is pulled or plunged into the rotating part etc.etc or pulled down onto the metal with a lever or something of the sort. Is that right?
Greenlight wrote:Thanks for all of your hard work and for sharing the results. I've spent a lot of time on the internet trying to find this information. It is virtually impossible to find anything.
Also, thanks for using 230 F instead of 100 F. This gives the test real world meaning.
As in every test it usually leaves you with more questions. You indicated that you did initial set up testing at room temperature and the results were approx. double that of the high temp. test. This begs the question as to what happens when the temperature is increased even more.
I am interested in learning more about the performance at even higher temperatures. In many (mine in particular) high RPM engines the big end of the rod distorts at high rpm and cause the bearing clearance to significantly reduce. When this occurs, the oil temperature in the bearing increases by a substantial amount. When the temperature increases the viscosity reduces, and the film strength follows suit.
A typical oil temperature increase in the bearing may be 200 F with the nominal (as assembled) clearances, but when the rod distorts and the clearances are reduced the oil temperature increase in the bearing may be 400 F more. The oils performance at these temperatures (in my opinion) is what separates a good oil from a great oil. Synthetic oils boil at a much higher temperature than pure dino oils and this makes them superior in many ways for racing applications.
The calculated connecting rod max. film pressure in my engine is ~17,000 psi and the main bearings are ~ 9,000 psi. All of the oils listed would easily meet the requirements at 230F. Because of rod distortion at high rpms I have problems with the rod bearings holding up and am getting metal to metal contact (sometimes complete bearing failure) with my current oil.
I know I may be asking for a lot, but could you test one or two of the oils in your test at a few temperatures (preferably high temperatures), so a film strength vs. temp. curve can be obtained? This general curve could act as a rough template for all of the oils in your test.
Thanks again for all of the very valuable information that you have shared.
Cogburn wrote:Interesting considering that my engines running VR1 look much worse than the ones running Brad Penn.
So far Brad Penn makes everything else look bad(methanol injected engines). Also those low zinc oils seem like they don't do so well with roller lifters. I wouldn't use any of the top oils on this list for a solid roller cam engine.
Maybe I'm just behind the times and the oils listed all got a lot better all of a sudden...
BrazilianZ28Camaro wrote:540RAT, I appreciate your effort, but I'll add my two cents ....don't forget the test you did only is valid where hydrodinamic oil wedge is formed.
On FT cammed engines, there are NO hydrodinamic oil wedge on the cam lobes/ lifter face so, the modern, SM or SN low zinc oils are DEATH to these engines.
As you might know the ZZDP is a extreme pressure additive to protect rubbing surfaces. Might be useful to the bearings on cold starts too...![]()
I'm far from a oil expert, but this is all we hear about new oils.
boxcartommie22 wrote:PackardV8 wrote:Very interesting and thanks for sharing.
jack vines
do a voa on lucas oils and see for yourself the lame additive package this oil has!! go to http://www.bobistheoilguy.com
Users browsing this forum: cjperformance, gmc406, nitrousking, oldjohnno and 14 guests
