LS heads on SBF
Re: LS heads on SBF
Postby 91stang » Fri Mar 16, 2012 9:46 pm
I'm only 28 and want to do something that even if it has been done it hasn't been over done. I can't afford to go any faster with the Windsor stuff I have, so why not build something unique? Even if it isn't a world beater it will be cool and might be something that will inspire more of my generation to think outside the magazine build.
1991 mustang 3040 with driver all motor all the time 9.70 @ 138.75 1.31 60' street driven mufflers and real tires, mt 275/60/15 radials with a 950hp holley.
91stang
Re: LS heads on SBF
Postby 91stang » Fri Mar 16, 2012 9:47 pm
MadBill wrote:You call it a Chord or a Fevy...
I see what your saying, except the LS has more in common with a sbf then a sbc. Maybe instead of LSX, LSW?
91stang
Re: LS heads on SBF
Postby 91stang » Fri Mar 16, 2012 10:12 pm
So looks like we are going with a 3.850 crank 6.200 rod and an Auto Tec piston with a 1.340 compression height. With my 1969 block with a 9.480 deck height that should leave the piston .015 in the hole. And leave us with around 11:1 compress with a 60cc head.
91stang
Re: LS heads on SBF
Postby needforspeed66gt » Sat Mar 17, 2012 12:13 am
So I guess the most important question at this point is whether to use a GM or a Ford head gasket right? :wink:
Nate
Engine Machinist
needforspeed66gt
Re: LS heads on SBF
Postby 91stang » Sun Mar 18, 2012 3:30 pm
needforspeed66gt wrote:So I guess the most important question at this point is whether to use a GM or a Ford head gasket right? :wink:
Haven't determined that yet. My thinking as of now is to use a Ford gasket and make the water in the heads meet the water in the block. Am I way off? Been a long weekend! LOL
91stang
Re: LS heads on SBF
Postby peejay » Sun Mar 18, 2012 6:32 pm
The Chevy uses Cleveland style water jacketing. The coolant comes back out through the deck and goes into the water pump/thermostat assembly.
I guess that is more similar to the LT1 than the Cleveland, but the LT1 gets honorary Ford status for putting the distributor on the front instead of up against the firewall.
Either way, it may be a golden opportunity to play with where the water comes out of the heads. Small ports on the rear face, large ones on the front, all going to a remote thermostat?
peejay
Re: LS heads on SBF
Postby revolutionary » Sun Mar 18, 2012 11:24 pm
Can't wait to see how this turns out. I eyballed doing that about 6 years ago. Mapped out the headbolt and water passage situation and it looked easy.
Daryl
Revolutionary Performance and Machine
revolutionary
Re: LS heads on SBF
Postby 91stang » Sun Mar 18, 2012 11:56 pm
peejay wrote:The Chevy uses Cleveland style water jacketing. The coolant comes back out through the deck and goes into the water pump/thermostat assembly.
I want the water coming into the heads, reverse cooling. It will have a remote water pump. The only bridge not to be crossed is the head gasket selection, that will be resolved this week after work some time. I have clevand, windsor, and several LS heads at my disposal, I'll get it figured out soon.
91stang
Re: LS heads on SBF
Postby 91stang » Sun Mar 18, 2012 11:58 pm
revolutionary wrote:Can't wait to see how this turns out. I eyballed doing that about 6 years ago. Mapped out the headbolt and water passage situation and it looked easy.
I wonder if that's why it was never done? It just looked too easy, no challenge.
91stang
Re: LS heads on SBF
Postby 91stang » Thu Mar 22, 2012 3:43 pm
Mocking up heads on block today to figure out my head gasket issue. Wish me luck. :D
91stang
Re: LS heads on SBF
Postby Unkl Ian » Thu Mar 22, 2012 5:06 pm
peejay wrote:I guess that is more similar to the LT1 than the Cleveland, but the LT1
Ford was smart enough to abandon distributors, for coil packs;
instead, GM came up with their stupid idea of hiding the distributor behind the water pump.
Just try changing the cap. #-o ](*,) [-(
Just because you never studied the Laws of Physics,
doesn't mean they won't try to kick your ass.
Unkl Ian
Re: LS heads on SBF
Postby 91stang » Thu Mar 22, 2012 11:57 pm
It looks like it will either be a Boss 302 or a copper gasket that we will be able to put holes where we want/need them. We are starting to come up with a plan for making the GMPP intake work.
91stang
Re: LS heads on SBF
Postby 3pedals » Fri Mar 23, 2012 6:51 pm
COOL build, I LOVE the fact that you are "building" this thing, not just slapping catalogue parts together. Thumbs up!
3pedals
Re: LS heads on SBF
Postby af2 » Fri Mar 23, 2012 7:23 pm
3pedals wrote:COOL build, I LOVE the fact that you are "building" this thing, not just slapping catalogue parts together. Thumbs up!
X2
GURU is only a name.
af2
Re: LS heads on SBF
Postby autodoctor911 » Sat Mar 24, 2012 10:17 am
cool Idea. I will be following this thread closely to see what works. I am looking at options for running a Ford small block in road racing, without spending a fortune on a yates head set up. this LS idea has me listening. I haven't seen any sbf heads that can match the flow of LS heads with a good port and smallish(<2.05i/<1.6e) valves, on a smallish(<4.06) bore.
Maybe the end result will be an inspiration for others, and a major head manufacturer may even start offering LS heads ready to bolt on a Ford engine, and manifolds, etc. it could be the next generation's CLEVOR. what'll it be called though?
WINDLSOR? too hard to pronounce
WiLSor?
autodoctor911
PreviousNext
Return to Engine Tech
Who is online
Users browsing this forum: Bing [Bot], Chris29, gramps, liljoe07, Majestic-12 [Bot], MSN [Bot], PPS, ssdoug, TTXPC, XfuelX, Zeke28 and 25 guests
