barnym17 wrote:Probably need to surface it after welding.How thin is it?
Dave Koehler wrote:Unless you made a window I don't think that thickness is a problem. Do you envision cracking it when tightened down?
Oh, wait. Are you talking about welding to the outside edges to get more flange/gasket area? If so, then yes the gasket surface will need to be surfaced. Been there.
wfolarry wrote:That stuff is like solder it doesn't work as well as they lead you to believe. I had a salesman come by the shop 10 years ago & give me the pop can demonstration. I then gave him a head to fix a stripped out hole. He couldn't get it to work. When he told me how much it cost I told him I can get it at the hardware store on the corner for 1/2 that. He went down there & bought some because he had to pay for the rod himself that he was using for the demonstrations.
rookie wrote:wfolarry wrote:That stuff is like solder it doesn't work as well as they lead you to believe. I had a salesman come by the shop 10 years ago & give me the pop can demonstration. I then gave him a head to fix a stripped out hole. He couldn't get it to work. When he told me how much it cost I told him I can get it at the hardware store on the corner for 1/2 that. He went down there & bought some because he had to pay for the rod himself that he was using for the demonstrations.
This stuff wasn't around until 2004 so you may have seen the products that were around before that they talk about here...
(Not to be confused with Alumaloy, Alumaweld, Alumarod, Durafix, Aladdin 3 in 1, or any other first generation rods most of them consisting of 3 alloys. HTS-2000 is a unique stand-alone product, Comprised of nine alloys that cost more to produce and through exhaustive testing led to this superior advanced technology. HTS-2000 has an elongation of 10% in 2 inches (rather than the standard 3% like the first generation rods listed above) which makes HTS-2000 3 times more flexible and stronger than any of its competitors. It also easily penetrates past impurities that lay below the metal's surface which may be impossible to penetrate with competitors materials. Also unlike the first generation rods HTS-2000 does not require steel or special cleaning brushes. All of this means not only a more expensive manufacturing process with new technology but also superior quality (this is the best brazing rod you can buy anywhere at any price) direct to the customer, see our testimonials and video and it will be easy for you to choose HTS-2000 as your #1 choice)
I just ordered some so I will let you know if it's worth a crap or not.
Belgian1979 wrote:After reading it all here, I had Mike put a tube of JB Weld in my order. I will probably epoxy the bar on the top of the flange while keeping it level to the flange, using 2 screws to keep it in place. After my ordeal with the engine, I'm not sure I will find someone suitable doing the correct surfacing of the manifold, short of driving 300 kms to my engine machine shop.
Users browsing this forum: A_VAS, BCLS776, bigjoe1, n2oracer, Nefario, Yahoo [Bot] and 22 guests
