Crank wiper & windage tray?
Postby mdross1 » Fri Feb 17, 2012 9:24 am
Just had a friend tell me if I did not use the oil control crank wiper and windage tray would be giving up near 25 hp, what do you guys think!
mdross1
Re: Crank wiper & windage tray?
Postby rfoll » Fri Feb 17, 2012 9:46 am
This stuff can be application dependent, but windage issues can easily eat 25 hp. That doesn't mean you will have a problem.
rfoll
Postby SupStk » Fri Feb 17, 2012 12:37 pm
Years ago i read an article where Bill Jenkins stated there is 60HP wasted in the pan of most engines. Since then I've played with many different pans, scrapers and windage trays. I still haven't found that 60 HP. However i feel the best solution is not to let extra oil run into the rotating assembly and any that gets there a scraper works to some extent. I haven't seen positive proof that the efforts i made with dirrectional baffles and windage trays make much difference. Bigger pans seem to be a good step..... Just my 2 cents.
Monty Frerichs
B&M Machine
SupStk
Postby Kevin Johnson » Fri Feb 17, 2012 3:30 pm
SupStk wrote:Years ago i read an article where Bill Jenkins stated there is 60HP wasted in the pan of most engines. Since then I've played with many different pans, scrapers and windage trays. I still haven't found that 60 HP. However i feel the best solution is not to let extra oil run into the rotating assembly and any that gets there a scraper works to some extent. I haven't seen positive proof that the efforts i made with dirrectional baffles and windage trays make much difference. Bigger pans seem to be a good step..... Just my 2 cents.
Mercedes, for one, has done the testing. On one of their straight six diesels there are five scrapers arrayed across the floor (straight fives as well). Maybe Bill was talking about an engine in motion and under acceleration (and perhaps pumping losses as well). Try tilting the dyno 45 or 60 degrees back and see how much power is parasitically consumed by an engine running at 5000 rpm while churning the oil. Good chance you'll blow your engine, though.
Kevin Johnson
Postby mdross1 » Sat Feb 18, 2012 10:01 am
My thoughts would be maybe at WOT would you ever see windage problems with oil sloshing up into crank pulling hp away.So maybe it is not such a big deal.
mdross1
Postby swatson454 » Sat Feb 18, 2012 10:49 am
SupStk wrote:Bigger pans seem to be a good step..... Just my 2 cents.
Did you see how deep a lot of the EMC pans were? Gotta be something there, assuming you can fit it in the car.
swatson454
Postby rfoll » Sat Feb 18, 2012 11:06 am
Hard cornering, hard acceleration, hard braking, or any combination can get the oil up on the crank. Once there, it tends to pull more up via surface tension. One G of force will put the oil at a 45 degree angle in the pan. I don't use anything in my daily driver stuff, but the effects of not adressing to issue on a track car can be measured on the time slip. One half qt. too high on the dip stick in my car will add a tenth sec. or more to the et.
rfoll
Postby Kevin Johnson » Sat Feb 18, 2012 11:30 am
http://www.youtube.com/watch?v=Ny9xl7iW ... re=related
Just in case you missed it, that is S C H R I C K. :lol:
Kevin Johnson
Postby #84Dave » Sat Feb 18, 2012 1:23 pm
Crank SCRAPER? If one were truly 'scraping' the oil off the rotating assembly, wouldn't that action cost TQ/HP? Most desirable to use an oil 'deflector'? And BTW...... does the 'pumping' action of the underside of all pistons moving up/down contribute to the 'windage' situation? Piston down = +pressure? Piston up = suction? Are there pressure 'pulses' in the lower engine case with the piston action affecting 'windage'? And does a constant vacuum in the lower case essentially eliminate windage, with 'oil deflection' then being the only concern? -Dave-
#84Dave
Postby Kevin Johnson » Sat Feb 18, 2012 3:10 pm
#84Dave wrote:Crank SCRAPER? If one were truly 'scraping' the oil off the rotating assembly, wouldn't that action cost TQ/HP? Most desirable to use an oil 'deflector'?
Yes, what's up with that? And why the heck does GM call a windage tray, errr ... an oil baffle plate, a deflector ?
#84Dave wrote:And BTW...... does the 'pumping' action of the underside of all pistons moving up/down contribute to the 'windage' situation?
Yes.
#84Dave wrote:... Piston down = +pressure? Piston up = suction? Are there pressure 'pulses' in the lower engine case with the piston action affecting 'windage'?
Yes.
#84Dave wrote:And does a constant vacuum in the lower case essentially eliminate windage, with 'oil deflection' then being the only concern? -Dave-
No.
As a show of respect for particle theory over kinetic theory: it was decided in engineering that particles can model an atmosphere.
Kevin Johnson
Postby #84Dave » Sat Feb 18, 2012 3:38 pm
Shucks...... now I'm really BAFFLED! So as I think about your answers, Kevin..... if I have a -13.6" H2O vacuum in the lower case, instead of the engine case being @ 29.92" Hg(sea level), the inside of the case now would be @ 28.92"Hg....... & the danged wind can still blow??!! This is killing me...... I need to go back to the Aerospace business! LOL! -Dave-
#84Dave
Postby SupStk » Sat Feb 18, 2012 5:05 pm
Talking now from just Dyno testing.... Kevin and Dave what do you recommend for modifications and how much power have you found?
What was your baseline set up and finished results?
Monty Frerichs
B&M Machine
SupStk
Postby Kevin Johnson » Sat Feb 18, 2012 5:18 pm
#84Dave wrote:Shucks...... now I'm really BAFFLED! So as I think about your answers, Kevin..... if I have a -13.6" H2O vacuum in the lower case, instead of the engine case being @ 29.92" Hg(sea level), the inside of the case now would be @ 28.92"Hg....... & the danged wind can still blow??!! This is killing me...... I need to go back to the Aerospace business! LOL! -Dave-
Why do you think that in a "vacuum" particles (fine droplets of oil) will not display kinetic behavior?
[Edit: on another thread I suggested a solution to a NASA problem with high speed windage persisting even with depressed atmosphere in a high speed gear train. The lubricant takes on the attributes of an atmosphere and the gears act as pumps. A likely solution is to go to a non-newtonian rheology.]
The ejection pattern will make a basic reversion to disks in 3-space but droplets still bounce, even off the surface of fluids and after being struck by the rotating assembly. There are some nice high speed films of droplet behavior on youtube.
Kevin Johnson
Postby Kevin Johnson » Sat Feb 18, 2012 5:25 pm
SupStk wrote:Talking now from just Dyno testing.... Kevin and Dave what do you recommend for modifications and how much power have you found?
A recent very modern engine designed with full CAD gained 3.5% output at peak rpms with a windage tray (deflector) modified with screening and a zero-clearance scraper. Sitting on a static dyno.
Kevin Johnson
Postby SupStk » Sat Feb 18, 2012 6:03 pm
So on the 600HP engines I'm dealing with now we are talking 21 Horses? I'm already there... but still a long way from 60 that Jenkins was talking about.
Monty Frerichs
B&M Machine
SupStk
Next
Return to Engine Tech
Who is online
Users browsing this forum: Big Speed, Bing [Bot], Google [Bot], pmann, The Electrician and 18 guests
