maple ridge puller wrote:Looking to build a low buck low rpm 454. Must run cast oem block and heads.9.5-1 compression max. Hydraulic Flat tappet cam that must have minimal lope and maximum .500 lift at the valve. 750 CFM carb and dual plane manifold. Going to run a set of 366 Oval Port truck heads. I guess my big questions here are what would be the best valve size to run? What kind of duration and lobe separation angle should I shoot for? Thanks in advance
maple ridge puller wrote: I may have to stay under 3000 rpm for insurance reasons
a 236 small port head would be your best choice in my opinion.maple ridge puller wrote:Looking to build a low buck low rpm 454. Must run cast oem block and heads.9.5-1 compression max. Hydraulic Flat tappet cam that must have minimal lope and maximum .500 lift at the valve. 750 CFM carb and dual plane manifold. Going to run a set of 366 Oval Port truck heads. I guess my big questions here are what would be the best valve size to run? What kind of duration and lobe separation angle should I shoot for? Thanks in advance
Users browsing this forum: Cogburn, Force Fed Mopar, Gary Evans, ProPower engines, rsguy, twl, wbclassics, xr4x4ti and 17 guests
