Dave Koehler wrote: ↑Mon Jun 08, 2020 10:42 am
If it can't do big end and small end then it is useless for shop use. Yes, I understand the center of mass idea. It's just not feasible for day to day use.
I think that you are correct that it is not for everyday production shop use as it assumes previous steps.
Modern sinter-forged rods are much more uniform in morphology and relative positioning of machining.
The original Porsche 928 sinter-forged rods were very accurate/reproducible in overall surface contour (morphology). The bore to bore distance from the big end to the small end was also very accurate. What was not accurate was the relationship between the two -- the pair of borings was randomly translated in the plane. As the amount of material machined away in each boring was very nearly the same, the weight or force due to the gravitational acceleration of that mass would also be nearly the same. The center of mass definitely would not be.
Each rod could be scanned and an analysis performed with very specific machining in 3-space specified with simultaneous attention paid to stress patterns. The cost of the time involved would far exceed the cost of a new bespoke rod created with finer manufacturing control.
I looked up the Shadograph patents previously (they are about seven or eight decades past) but pulled the research from the thread because it was distracting from considering the specialized use of particular manual tools.
