connecting rods weighing question
What would be a good way to weigh small ends and big ends on an improvised way ? How much difference can there be between the small ends and big ends of a set of rod before the balance is thrown off ?
Thanks
Thanks
- Wolfplace
Re: connecting rods weighing question
You need some sort of arbor to find the center of the bores to weigh them correctlyBelgian1979 wrote:What would be a good way to weigh small ends and big ends on an improvised way ? How much difference can there be between the small ends and big ends of a set of rod before the balance is thrown off ?
Thanks
The rod also has to hang level
Like so
How much is very subjective,, guess it depends on what you will accept
I have seen so called balanced assemblies that had parts over 10gms different so I guess this is "acceptable" to some,, not to me
I balance to .5 gm per end & .5 total rod weight if possible
That is not ± .5 it is .5
You can also "juggle" parts to come up with acceptable numbers because all if the reciprocating weight is cumulative
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
A tour of my shop
The Dyno
John Wayne
When I rebuild most customers engine's , I always try to sell balance the engine as the results are justified. normaly a decent street engine will come in for rebuild and when we find the balance out by 10 grams or more the customer always say's WOW I didn't feel a shake before BUT I can certainly feel the difference now. Wolfplace has it correct, in my opinion.Belgian1979 wrote:What would be a good way to weigh small ends and big ends on an improvised way ? How much difference can there be between the small ends and big ends of a set of rod before the balance is thrown off ?
Thanks
- Wolfplace
I can't edit the damn post so to make it clearWolfplace wrote: You can also "juggle" parts to come up with acceptable numbers because all if the reciprocating weight is cumulative
The last sentence is supposed to say
You can also "juggle" parts to come up with acceptable numbers because all of the reciprocating weight is cumulative
NOT
Mike
A tour of my shop
The Dyno
John Wayne
A tour of my shop
The Dyno
John Wayne
When the weight unbalance is greater than 15 grams per throw it will have a shake so I have found. Where it comes in as a shake may vary.
I find that just for the customers satisfaction knowing it needs to be balanced I show them two complete piston rod assembles on the scale, and how bad they come.
Against my better judgment, I'll ask:
what does the rod's center of gravity have to do with reciprocating vs. rotating weight?
- Wolfplace
I don't understand the question?panic wrote:Against my better judgment, I'll ask:
Mike
A tour of my shop
The Dyno
John Wayne
A tour of my shop
The Dyno
John Wayne
Ok, I was trying to measure things with a wrist pin on a scale, but I can see now that it would not yield good results.Wolfplace wrote:You need some sort of arbor to find the center of the bores to weigh them correctlyBelgian1979 wrote:What would be a good way to weigh small ends and big ends on an improvised way ? How much difference can there be between the small ends and big ends of a set of rod before the balance is thrown off ?
Thanks
Like so
Does anyone here have an idea how good Oliver rods are concerned balancing of small/big end. I seem to have a difference of 1 gr across the total rod weight.
My crank had to be rebalanced and used one rod to do so.
I found some more differences between the small/big ends. But apparently my method is no good.
BTW : how accuratly are cranks balanced. I hear that it would be futile to go really small.
I worked with the great Smokey Yunik on a engine project years ago and asked him about engine balancing and his reply was balancing is an imperfect science and I think he makes sence with that statement.Belgian1979 wrote:Ok, I was trying to measure things with a wrist pin on a scale, but I can see now that it would not yield good results.Wolfplace wrote:You need some sort of arbor to find the center of the bores to weigh them correctlyBelgian1979 wrote:What would be a good way to weigh small ends and big ends on an improvised way ? How much difference can there be between the small ends and big ends of a set of rod before the balance is thrown off ?
Thanks
Like so
A few years ago I went to another shop a guy was picking up his rotator and the shop owner was saying he had everything with in one tenth of a gram and was pretty proud of that and on the final spin it was with a couple tenths, After the bob weights we off I told him to put them back on a respin the crank and he did and the crank did not spin up the same it was out a few grams on both ends and he looked like the little boy that shit his pants
Its like the oil weight its only a gestimate at best. I have had rods out more then 5 grams on the big end and had to make up 3 different bob weights to make it come out right rather then hack up a new set of Lunati Pro mod rods.
Website is up and running
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
How close a crank is balanced all depends on who did it. I tell customers to get rotating assy's unbalanced because mail order balance jobs are rarely very good. How can they balance an assy when no pistons or rods have been removed from their original packaging? The worst I saw was an LS assy that the customer had ordered balanced but it shook so bad he had to take it back out and it required 80 gram removal on both ends. An extreme case but it happened none the less. Some OE's are very close to balance from the factory. Anything German and surprisingly most British inline cranks are very close, most of the time requiring no balance at all, go figure. Like Mike said, .5 gram is what I shoot for. If you're going to do it, it doesn't take that much longer to do it to near perfect so why not? I think the accepted industry standard is 3 grams. My balancer will read 0 if the crank is less than 3 grams. I have to go in and change the calibration every time so that it will read to two decimal points. I think it's probably more important to have all the rotating parts weigh the same than it is to balance the crank to the bobweight.
"do it right or do it right away"
http://www.motionmachineinc.com/
https://www.youtube.com/watch?v=ZgIZbveknDs
FYI just read Olivers website and it states they have their rods balanced within .5 gram. My scale here only goes to 1 gram so seeing the total weight on the rods I tend to believe them somehow.
By ensuring that the rod is level doesn't really have anything to do with finding the rod's "center of gravity". By having the rod level, the weight of the big end is not influencing the weight of the small end and vice-versa. The ultimate goal is to segregate the weights of small end and big end from each other. The small end of the rod is reciprocating weight and the big end is rotating weight.
Bill
SAE Member (30 years)
FWIW, I've never needed to touch an Oliver to the grinder. They are always within spec. However, trust, but verify.
jack vines
jack vines
But... it's not. The separation of motion paths* isn't related to how much weight is on either end, but on what a molecule in any position is doing.
* very little of the rod mass is pure reciprocating or pure rotating weight.
