engine kicks back and turns over backwards
Re: engine kicks back and turns over backwards
Postby paul s. » Sun Feb 12, 2012 2:41 pm
Are you sure your pointer and tdc on your balancer are accurate?
http://www.sandovalperformance.com
custom built Pontiac 400's and strokers
paul s.
Postby #84Dave » Sun Feb 12, 2012 2:54 pm
And if you're using a 'dial-back' timing light, throw it in the trash can! 80+% of the dial-backs are inaccurate. Anywhere from 2-12 degrees inaccurate! Buy a Flaming River,Sears, or MSD. OR...... borrow a couple of your buddie's timing lights, that aren't dial-back, & compare to yours. -Dave-
#84Dave
Postby reven327 » Sun Feb 12, 2012 5:02 pm
It wouldnt start at all, if it was 180 out. It does start and runs great when it does start. However 7 out of ten times it kicks back and back out of carb a puff of white smoke. I am gona try and pull dizzy and back it up a tooth or forward a tooth . I am thinking it is not in sync with valves a tooth or so.
reven327
Postby reven327 » Sun Feb 12, 2012 5:08 pm
paul s. wrote:Are you sure your pointer and tdc on your balance are accurate?
No , however it is all new parts . In witch are the correct for mt application. So if i were to guess , i would say yes it is accurate.
reven327
Postby IMCADW » Mon Feb 13, 2012 1:31 am
I'd venture to say you're balancer and pointer aren't marked correct. Get it running and dial it back some and see what it does. It won't hurt the engine.
IMCADW
Postby dieselgeek » Mon Feb 13, 2012 9:58 am
nobody's asked if your timing at cranking RPM is steady? make a paint mark on the balancer so you can see it VERY well at low RPM, see if it's bouncing all over the place when you are cranking. Bad wiring/grounds/power and even bad starter contacts can play havoc with low rpm ignition timing. Sounds like you have sparks happening at the wrong time only during cranking.
Custom EFI setup and calibration
dieselgeek
Postby reven327 » Mon Feb 13, 2012 7:00 pm
Thx for everone's help! All fixed,the dizzzywas off a tooth .
reven327
Postby IMCADW » Mon Feb 13, 2012 7:38 pm
Someone care to explain "Tooth off" for me. I've been around racing engines for over 10 years and have never had a problem being off a tooth on the distributor.
IMCADW
Postby dieselgeek » Mon Feb 13, 2012 7:49 pm
IMCADW wrote:Someone care to explain "Tooth off" for me. I've been around racing engines for over 10 years and have never had a problem being off a tooth on the distributor.
It screws up the phasing such that SOME of the sparks jump to the wrong tower - and then you get the intake backfire, starter kickback, etc. You can usually tell when this is happening as cranking timing is actually all over the place. Noob Mistake #1 but we've all been there, right? :D
dieselgeek
Postby IMCADW » Mon Feb 13, 2012 7:53 pm
I guess if I'm off on phase I just spin the dizzy one way or the other.
IMCADW
Postby dieselgeek » Mon Feb 13, 2012 7:56 pm
IMCADW wrote:I guess if I'm off on phase I just spin the dizzy one way or the other.
You must be using a crank trigger then? spinning the dizzy when you're using a pickup coil mounted to the body of the dizzy, throws the timing off.
dieselgeek
Postby IMCADW » Mon Feb 13, 2012 7:58 pm
No, I'm using an MSD. I've heard it talked about and have never once seen the distributor being off a tooth cause a motor to not run right. Maybe I am missing something?
IMCADW
Postby IMCADW » Mon Feb 13, 2012 8:00 pm
I have seen guys be off 180 degree's though...
IMCADW
Postby reven327 » Mon Feb 13, 2012 8:12 pm
Deisel geek, in reference to your last post tht is exactly wht was happening. Thx for the post!! And for the guy how has been working on engines for ten yrs and never heard of being off a tooth, every day is a learning experience!
reven327
Postby IMCADW » Mon Feb 13, 2012 8:14 pm
Explain, that's what I'm asking. I've heard of "tooth off" many times, but it makes no sense.
IMCADW
PreviousNext
Return to Engine Tech
Who is online
Users browsing this forum: Bing [Bot], BlitzA64, clay, dcl, g68bird, Runit, swatson454 and 23 guests
