Gaterman Lifters?
Re: Gaterman Lifters?
Postby CamKing » Wed Feb 08, 2012 11:22 pm
briancb1 wrote:Are the Delphi LS7 lifters okay to handle .650"?
We buy the LS7 lifters right from the local GM dealer, and we often use them with .648" lift(.360" x 1.8 rockers)
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
CamKing
Postby briancb1 » Thu Feb 09, 2012 2:49 am
After talking with my friend about the discussion here, he is thinking that going with the US Delphi lifter is a safe bet.
Thanks for all the help guys, I appreciate it.
briancb1
Postby 1745greg » Fri Feb 10, 2012 6:49 pm
I dont have any experience with the LS engines so this may be a dumb question but here it is. Does anyone use or make solid roller lifters for these engines? Or is everyone using hydralics for racing?
1745greg
Postby briancb1 » Sat Feb 11, 2012 4:01 pm
There are solid roller available, but it doesn't seem to be commong.
On a carb'ed motor i wouldn't see a problem but on a factory injected car it would render the knock sensor usless and many people still use these motors for a street car.
briancb1
Postby CamKing » Sat Feb 11, 2012 4:48 pm
1745greg wrote:I dont have any experience with the LS engines so this may be a dumb question but here it is. Does anyone use or make solid roller lifters for these engines? Or is everyone using hydralics for racing?
We ran solid rollers on the Daytona Prototype LS engines. I believe they were Jesel lifters.
Crower makes a solid lifter for the LS also.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
CamKing
Postby 1745greg » Sat Feb 11, 2012 7:51 pm
Thanks all for the answers to the solid lifter question,If I build one of these engines it will have a carburator and distributor..
1745greg
Postby hsutton » Sun Feb 12, 2012 12:06 am
My son had a Trailblazer SS with a stock LS-2. When he first started to hop it up a little he had problems with the LS-2 lifters. We bought a set of the more expensive Morel tie bar lifters and a small cam to go along wth some 225 CNC TFS heads. He decided to trade vehicles late last year so he pulled the race oriented stuff and went back to a factory LS-7 lifter. He said those factory LS-7s were of much better quality than the LS-2s that were stock and would rev over 6K rpms without any problems, unlike the LS-2 lifters. They also made the TBSS almost a half second quicker than it had been stock and were very reasonably priced.
hsutton
Postby 69-CHVL » Sun Feb 12, 2012 9:19 am
I picked-up a set of Trick Flow lifters, and was sad to see they were Gatermans. Not that I have any experience with them, but I had a set of them side by side to a Cranes. Although they are VERY similar, they Cranes just seemed a little beefier, especially around the tie-bar area.
VINCE 69 CHEVELLE
509/AFR305/XR286/5SPD/3.90
69-CHVL
Postby cstraub » Thu Jul 12, 2012 3:38 pm
Just to clear up a few things here. Morels inexpensive lifter is made in conjunction with Eaton and is a joint venture. This lifter is being produced to compete with the offshore garbage. NOw the lifter is designed for OEM performance cam upgrades based on OEM .700" wheel designed profiles. Morel intended this to be used with "HOT" cam applications and lift was not to exceed .600 and duration at .050" a max of 230.
Any marine or endurance engine needs to use the 100% made in house Morel .750" wheel stuff. The Morel street lifter's capabilities have been over sold by some. Trying to save money in the valvetrain will bite you everytime.
Chris Straub
Performance Mfg.
www.straubtechnologies.com
www.stefs.com
cstraub
Postby briancb1 » Fri Jul 13, 2012 7:09 pm
Wow, where were you able to find this information?
Im pretty impressed you dug that up, I couldn't find anything really specific to why they were so cheap compared to their "top-tier" lifters at double the price.
It seems like they have no advantage over a stock Ls7 lifter unfortunetly...
briancb1
Postby rskrause » Sat Jul 14, 2012 6:20 pm
I have a problem with the "Made by Morel" being an import product. That's misleading. I prefer to buy US stuff for a variety of reasons and at least feel that an import should be clearly labelled anf advertised as such. Callies does a good job of this with the Compstar line - thye make the origin of the forgings widely known.
Shame on Morel, IMHO.
BTW - the GM lifters work fine and are inexpensive and widely available.
rskrause
Postby cstraub » Mon Jul 16, 2012 11:47 am
The Eaton plant is in Mexico. The lifter has over 55% US content.
Chris Straub
Performance Mfg.
www.stefs.com
cstraub
Postby novadude » Mon Jul 16, 2012 11:50 am
Personally, I would have no problems with a part manufactured by an Eaton-owned plant in Mexico. Eaton is a large global company, and I have no doubt that they are applying good manufacturing practices / QC methods in all their plants. I would be more concerned if Morel was just subcontracting manufacturing to the lowest bidder in China / Mexico. I think that is what you get when you deal with some of the smaller companies who aren't partnered with a Global manufacturer. That is where the problems start.
novadude
Postby cstraub » Mon Jul 16, 2012 11:58 am
Morel is a Union shop and family owned for 3 generations. I have you know Ed is not interested in shipping jobs overseas. Ed's family has been envolved with Eaton for decades and being a racer that knows some can not afford the best he did what he thought was best to bring out a more price effective lifter for the guy building a mild performance application.
Chris Straub
Performance Mfg.
www.stefs.com
cstraub
Postby briancb1 » Tue Aug 14, 2012 5:21 pm
cstraub wrote:Just to clear up a few things here. Morels inexpensive lifter is made in conjunction with Eaton and is a joint venture. This lifter is being produced to compete with the offshore garbage. NOw the lifter is designed for OEM performance cam upgrades based on OEM .700" wheel designed profiles. Morel intended this to be used with "HOT" cam applications and lift was not to exceed .600 and duration at .050" a max of 230.
In your opinion, would these work for me? Would you use them?
I'm considering removing my GM "CTSV-R Lifters" PN 88958689 that have around 3000 street miles with another high-rpm lifter when I pull the heads to get some port work done.
Its an 454" LS7 application:
Intake: 304°seat /253° .050" /173°.200"/ .360" Lobe (.648 lift)
Exhaust: 312° seat / 259° .050" / 178° .200" / .360" Lobe (.648 lift)
Peaks around 6500 rpm and I shift at or just shy of 7000 RPM. The PN 88958689 lifters have a bad following online it seems and I'd hate to see something get damaged as this is a $15,000 engine.
briancb1
PreviousNext
Return to Engine Tech
Who is online
Users browsing this forum: 77cruiser, bigjoe1, Steve Smith and 25 guests
