,,, i know what i've seen on a dyno ,, a good one pulls about 430 hp ,, i watched that certain engine win a few races ,, in a great car with a talented driver ,, with legal headers
autodoctor911 wrote:I was thinking more about the really hard to catch stuff. If the cam has more duration then yes vacuum would be lower and it would not pass a teardown most likely. I am not sure if they get out the dial indicaters and degree wheels, but I suggest something easier:
CamKing wrote:autodoctor911 wrote:I was thinking more about the really hard to catch stuff. If the cam has more duration then yes vacuum would be lower and it would not pass a teardown most likely. I am not sure if they get out the dial indicaters and degree wheels, but I suggest something easier:
You're pissing into the wind.
Here's what many use to check the Crate cams now.
http://www.audietech.com/cam-pro-plus/techinspect.html
The quality of the stock 604 cams(Made in Mexico) is so bad, we can cheat even this system for a 15hp gain.
Crate engines have no place in Racing, and they've put a lot of good local engine builders out of business.
IF you want to run a less expensive class, go race bombers or any of the entry level classes.
The long term health of auto racing is tied to the health of the race engine builders, and the aftermarket parts suppliers. Crate engines are an attack on both of those groups.
My goal is to make sure the disparity in power is so great, that people will choose to race in non-crate engine classes, and that the cost to tech Crate engines will get so expensive, that track owners will do away with the crate engine classes.
Users browsing this forum: Bazman, BirdMan, Bos's5.0, BrazilianZ28Camaro, fastvette, FC-Pilot, Google [Bot], Majestic-12 [Bot], n5ifi, Plaintoast, ProPower engines, SalP, swatson454, williamsmotowerx and 31 guests
