broken world heads
Re: broken world heads
Postby avengerengines » Tue May 22, 2012 1:49 pm
Then our suspicions were correct. It's a poorly designed head. :roll:
avengerengines
Postby robert1 » Tue May 22, 2012 2:03 pm
How many heads were cracked in the SPC analysis?
robert1
Postby SchmidtMotorWorks » Tue May 22, 2012 2:40 pm
We've had the foundry and engineers look this over and the problem is not one of design, but how the O-rings are seated.
With the extra bolts along the outside of the head, there is more clamping force on the outside. Because of this, if the o-rings aren't seated completely or correctly, the extra force will pull down with the o-rings being a fulcrum point and cause this condition.
yeah, that's what happened
http://www.youtube.com/watch?v=pkYNBwCEeH4
Edit:
After reading your post again, I'm thinking you probably work for a competitor or are after revenge against World, no one could be this self destructive,,,could they?
http://www.schmidtmotorworks.com CamFlowRPM software, CAD CAM CAE CFD, CNC Machining.
SchmidtMotorWorks
Postby 1928rutherford » Tue May 22, 2012 10:05 pm
I understand what the other people are saying about toqueing the extra bolts down to cause the heads to crack but what bothers me is that world designed these heads to be the ultimate power adder head. I haven't broken anyone elses heads and I wanted to beleive I was building the best inline valve small block ford. These heads flow great on my flow bench and I would like to use them at some where near their potencial but I beleive they can"t handle the boost level that I was running . Why dosen't world admitt I was way over their design specs. I was miss led by their advertising and I paid the price.
1928rutherford
Postby Larry Widmer » Wed May 23, 2012 8:05 am
We O-ring every boosted or endurance Honda head we do. We don't run a receiver groove and we run Cometic MLS head gaskets. When we're done with the castings, they are thin and brittle, but we have never had a head break.
As I see it, the continuous "spin" from World speaks volumes about their committment to quality...and ultimately their customers.
Larry Widmer
Show Guest
Show Guest
Postby MadBill » Wed May 23, 2012 8:16 am
The best face I can see putting on the situation is that the cantilever/O-ring issue is an unanticipated failure mode that World must address via a redesign, if customer confidence is to be regained.
"There's no product that can't be made cheaper and worse."
Postby PFC1 » Wed May 23, 2012 8:18 am
Here's my question... Are you doing any re-engineering of the head at this point?
Bret
The heart of the wise inclines to the right, but the heart of the fool to the left. Ecclesiastes 10:2
PFC1
Postby nascarfan7 » Wed May 23, 2012 10:03 am
Bah!
No re-engineering needed. These issues are because of internet trolls and extortion attempts. Change the company name every now and then and tada.... "Not our problem anymore"
After reading a ton of forums with people that have had issues with Bill Mitchell/Hardcore/World/ect. products I did not see ONE customer that was satisfied with the results. That speaks volumes to me. After seeing how an employee representing the company has acted here seals the deal.
Takes a lifetime to gain a customer and only a second to lose one.
nascarfan7
Postby ZIGGY » Wed May 23, 2012 10:45 am
I think nascarfan about covers it.
ZIGGY
Postby miniv8 » Thu May 24, 2012 3:09 pm
After seeing this picture, I never would have guessed the foundry expert engineers would come to this conclusion.
miniv8
Postby SchmidtMotorWorks » Thu May 24, 2012 4:39 pm
You need to find the right engineers.
SchmidtMotorWorks
Postby Bazman » Thu May 24, 2012 6:38 pm
I guess it is for reasons like this that companies like Dart do well with the pro racers. I brought Indy Cylinder heads into my country back in the 90's and promoted them. Back then they were good quality and records got broken not parts. Now I'd not go near them (like a number of other big names).
The list of block and head makers that make AND MAINTAIN quality control and design a top priority is short in my view.
Ok you pro race engine builders - what names would you add to a shortlist of companies that you can vouch for having consistently good design and quality castings?
I'm not a engine builder but I'll start the list - talking as cast/billet not finished:
1 - Dart - not necessarily the very best always, but consistently very good and will almost always do the job
Bazman
Postby MPac » Sat May 26, 2012 1:23 am
Bazman wrote:I guess it is for reasons like this that companies like Dart do well with the pro racers. I brought Indy Cylinder heads into my country back in the 90's and promoted them. Back then they were good quality and records got broken not parts. Now I'd not go near them (like a number of other big names).
I've never personally ran them but I've only heard good about Patriot Performance.
matters not whether you win or lose; what matters is whether I win or lose
MPac
Postby 1928rutherford » Fri Jun 08, 2012 11:02 pm
so I hace a set of these heads that I will probably never use. I have a pretty good business up here in Canada and have deal"t with many manufactures and most seam to want to stand behind their product. I have never asked for anything from World other than maybe they should admit that I was trying to do something that their product was not designed to do. I find it odd that no one knows of any one that has defended Worlds reputation by sayin that they use these heads in heavily boosted applications with no problems.
1928rutherford
Postby raynorshine » Sat Jun 09, 2012 12:13 am
1928rutherford wrote:so I hace a set of these heads that I will probably never use. I have a pretty good business up here in Canada and have deal"t with many manufactures and most seam to want to stand behind their product. I have never asked for anything from World other than maybe they should admit that I was trying to do something that their product was not designed to do. I find it odd that no one knows of any one that has defended Worlds reputation by sayin that they use these heads in heavily boosted applications with no problems.
i find that extremely ODD as well
raynorshine
PreviousNext
Return to Engine Tech
Who is online
Users browsing this forum: acmepaul, ausbullet, Bing [Bot], BlitzA64, bobalattie, constrictor, dieselgeek, Dragsinger, E85V6, fastback69, Google [Bot], jason snyder, Lockwire, ProPower engines, ptuomov, redfox91, rs6868 and 25 guests
