broken world heads
Re: broken world heads
Postby Kevin Johnson » Tue Feb 28, 2012 11:49 pm
cpmotors wrote:
1928rutherford wrote:Image Hope I got this right but here is a picture of the new head and you can see the slight mark centered on the bolt holes and the intake and exhaust seats that john said were both uncut.
Are you refering to the line at the outer row of bolt holes?
I'm sure you know this but the triangle area around each of the outer bolt holes are where the cutter/head deflect, a combination of the setup, machine spindle,interupted cut, and casting not being rigid as one might like. Obviuously not intended to be used as the final surface prep to seal a head gasket, but a production style finish.
Also, the coolant ratio looks weak and the cutter inserts need to be rotated. :D
I combined the pictures and rotated them. You're the expert but to me the marks look qualitatively different.
Kevin Johnson
Postby mmmitch588 » Wed Feb 29, 2012 4:58 am
The one on the left looks to have a crack :lol: Only joking, but they look like different casting as around the pushrod area looks different
mmmitch588
Postby Kevin Johnson » Wed Feb 29, 2012 5:02 am
mmmitch588 wrote:The one on the left looks to have a crack :lol: Only joking, but they look like different casting as around the pushrod area looks different
I would guess the original head had those tubes installed after purchase (?).
Kevin Johnson
Postby mmmitch588 » Wed Feb 29, 2012 6:10 am
Kevin, why? They serve no purpose, that is if they are tubes installed.
mmmitch588
Postby Kevin Johnson » Wed Feb 29, 2012 6:30 am
My guess would be that the intake passages were ported and the tubes serve to reinforce thin areas resisting 30lb boost.
Kevin Johnson
Postby mmmitch588 » Wed Feb 29, 2012 7:49 am
Point taken, but it looks like they machined material away to fit the sleeves which kinda defeats the purpose, don't ya think?
mmmitch588
Postby Kevin Johnson » Wed Feb 29, 2012 7:56 am
mmmitch588 wrote:Point taken, but it looks like they machined material away to fit the sleeves which kinda defeats the purpose, don't ya think?
The tubes themselves appear close in OD to the ID of the area in the new casting. The area machined/ground away at the mounting face may have been to allow room for the tooling for drilling or installing. In any event, Steve could comment on this directly.
Kevin Johnson
Postby FuelieNova » Wed Feb 29, 2012 8:19 am
Check this out... John any thoughts??
http://www.yellowbullet.com/forum/showthread.php?t=453515
Tom
FuelieNova
Postby Transman » Wed Feb 29, 2012 9:18 am
Extortion, wow.. now I've seen it all.
http://www.yellowbullet.com/forum/showt ... p?t=453515
Dealer for TCI, JW, BTE, Trans Specialties, Jesel, Impact, etc.
Transman
Postby rookie » Wed Feb 29, 2012 10:58 am
FuelieNova wrote:Check this out... John any thoughts??
Tom
So he doesn't think people should say anything about broken World parts on internet forums but it's OK for him to bash people from this forum on the YB forum... [-X John
Has Anything You've Done Made Your Life Better?
rookie
Postby mmmitch588 » Wed Feb 29, 2012 5:54 pm
Perhaps the Admin. guys here should take a page from the guys on YB & start closing the bullshit threads down like what this turned out!!! #-o
mmmitch588
Postby SchmidtMotorWorks » Wed Feb 29, 2012 6:29 pm
mmmitch588 wrote:Perhaps the Admin. guys here should take a page from the guys on YB & start closing the bullshit threads down like what this turned out!!! #-o
What specifically do you dislike about it?
http://www.schmidtmotorworks.com CamFlowRPM software, CAD CAM CAE CFD, CNC Machining.
SchmidtMotorWorks
Postby JoePorting » Wed Feb 29, 2012 7:51 pm
This is probably the best train wreck thread yet.
Joe Facciano
joefacc1@yahoo.com
JoePorting
Postby rookie » Wed Feb 29, 2012 7:56 pm
I don't know about you but I don't need a moderator to fight my fights or to hide behind.
rookie
Postby SWR » Wed Feb 29, 2012 8:05 pm
I can tell you as a mod it's been VERY close a couple times... derogatory comments started flying and when they are posed at the person, not what he's saying I feel the fuse burning...
-Bjørn
"Impossible? Nah...just needs more development time"
SWR
PreviousNext
Return to Engine Tech
Who is online
Users browsing this forum: Google [Bot], more cubes, SKeown and 27 guests
