You are right - there are many claims out there. But just as it is true there are some scams.... it is also true where there is enough smoke..... fill in the blanksMax Effort wrote:
The world is full of fuel mileage claims and related anecdotal stories,
Most of them are HOGWASH!
I have an open mind, but not a gullible one. All I demand is proof.
BSFC: (brake specific fuel consumption) the pounds of fuel it takes to make one horsepower for one hour.
Prove the claim on the Dyno or you have nothing but another fantasy.
The problem here Max Effort is you have proof - it just is not in the form you like. I do not need to prove anything - what am I - on a crusade for the makers of acetone here?
I simply shared what works for me - and got called a gullible liar by clear inference...
The real proof is mpg going up - period.
BSFC is only an indicator of what you expect in the real world of driving. Time and speed measured over a distance, and actual mpg - those are the benchmarks in the real world.
The key is you trust BSFC but not someone's claimed mpg, and you are not "gullable" enough to try it to find out for yourself.
Fair enough. I only mentioned it for the sake of a few that might try it. I knew most would not go near it before posting.
Meanwhile - I used to celebrate if I could get 300km by half tank. Last tank I got 450km by the same half mark. Do the math.
In other words I have not been exaggerating on this thread. 6.5mpg gain from acetone - 1mpg straight away, the extra 5.5 came after nearly 3500 miles of decoking.... engine runs quieter than ever, and smoother than ever. It runs hills typically a gear higher, and boosts quicker. It will out perform any other SUV I have come across of this make and model and year, and gets heaps better mpg.
mpg and 0-100kph mean more than BSFC in a road car. IN a race car, mpg average and track times STILL means more than lab results and dyno results. You are putting the science before the main event.
My tanks get filled to the same spot each time - because I insist on doing my own. I add the acetone in first by estimating (with calculator) what I will need and my guess is usually within 5ml... I rarely need to top the acetone up after the fill - 10ml at most.
You are free to not try it - just don't call me a liar.
