700+hp sbc 23 degree heads
user-9274568
Re: 700+hp sbc 23 degree heads
Post by user-9274568 »
CamKing wrote:Thanks, I just stapled it to the wall, above my desk.
cool.. It has a really nice velocity profile as well.
PS.. It comes in iron also!
Stan Weiss
Vendor
Post by Stan Weiss »
cspeier wrote: Here is a pdf of a set I just did last week. Just a valve job and a little blending.
http://www.speierracingheads.com/v2.72_flow.pdf
Chad,
I have to ask because I see many people do it this way. Why when you calculate the throat velocity do you not remove the valve stem csa?
Stan
user-9274568
Chad,
Stan
it's probably wrong.. :) But in my defense, I "know" how it effects the numbers.. Different sized stems and such...
I should probably rework my spreadsheet. I'm just not smart enough to do it. Do you wanna? I'd pay you..
Stan Weiss
Vendor
Chad,
Stan
Chad,
I do not work with Excel that much. But if you email me the spreadsheet in xls format (not the newer xlsx) I will see what I can do. No charge. :D
Stan
srweiss@erols.com
mdross1
Post by mdross1 »
cspeier wrote:
Been away from it too long I guess.Always was led to believe that a port will only flow what is let through the seat,and was taught the 85% rule.Make the seat opening at least 85% of the valve diameter,always figured that the pinch area was not a big deal.Obviously I do not play with a flow bench,sure would like to! Honestly the flow numbers are interesting and I will always enjoy talking about technical side,bottom line is I need a topend that will give me the big number or very close to it and on street gas.Because this motor will be in a motorcycle torque is not a big deal.Will insist on instant throttle response don't we all.
Yea, you've been away too long! :) The port will only flow what is let through the minimum CSA, wherever that might be. I agree, it should be the seat ring. A 85% seat is really small. Even my street heads are 90%+..
Of course it all makes sense,great getting up to speed and feeling better all the time about getting what I'm looking for.Once all the parts are here polished,clearanced,balanced and assembled it will be a joy dailing it in.Finding this forum hearing what you guys are saying sure takes the pressure off.Guess it's time to arcive my old books since thay are just a little outdated.
levisnteeshirt
Post by levisnteeshirt »
bigjoe1 wrote:The alu block is NOT a good idea, I have had several really BAD results. Just get a Dart iron block, 434 crank assembly, some AFR 245 heads, and you can make 750 HP on pump gas. On serious race builds, I am seeing very close to 900 HP with the same AFR 245 heads and a lot of trick parts to go along with them. Do not waste your money on the alu block.
JOE SHERMAN RACING ENGINES
i saw one mag article of a 434 , 18 degree heads , small roller , 252/260 on a 110 ,, it got over 700 hp on pump gas
mdross1
Post by mdross1 »
Sure would like to know more about this one,just to get some ideas.
user-9274568
Want to thank Stan for hooking me up with an updated spreadsheet! Very cool of him!
THANKS
BlitzA64
Post by BlitzA64 »
:D ^^^^^^^^^^^^^^^^^^^^
Stan Weiss
Vendor
cspeier wrote:Want to thank Stan for hooking me up with an updated spreadsheet! Very cool of him!
THANKS
Chad, you are welcome.
I would like to believe that why most of us are here is to share knowledge and help others out when we can. :D
Stan
mdross1
Post by mdross1 »
THANKS
Stan
Exactly why I for one am using a site like this.Been building engines most all my adult life, since the 60's.An aweful lot of old school still lurking around the grey matter which by the way has served me very well.Getting these motors into the 1.8 to 2.0 or more hp per ci be streetable and reliable,makes the need to know more a requirement.Mike Ross
Tony B
Post by Tony B »
What issues have you had with aluminum blocks????TB
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
The biggest problem is always about stripped out threads every where. I have seen heads studs. bell housing bolt holes. motor mounts holes and so forth have the threads pull out. When one was used with NOS, the leak downs were terrible after just a few runs. They also seem to loose 4o or more Hp compared to a Dart cast iron block. The cost to save 100 pounds does not seem to be a good deal at all
JOE SHERMAN RACING
Avadoo
Post by Avadoo »
....Out of interest Joe, how much shorter did you build the alu block over your normal iron version ?
Im still on the fence as to alu Dart or lightened Iron Dart for a 582/598 road racer winter build.
Tony B
Post by Tony B »
You lose 2% going aluminum, but circle track guys don't care, they need the weight off to get their percentages right. We do quite a few of them, love them. Call Brodix, they offer many options, most at no extra cost. Yes, they don't hold the same vacuum as an identical engine built with steel, but we have no issues with ring seal, if they are properly prepaired.TB
P.S. DO NOT BUY A DART ALUMINUM BLOCK. The steel ones are great, but the aluminum ones leak like a stuck hog, and they crack. Don't believe me if you want, but you better ask an engine builder b4 you make a purchase. TB
