AFR heads on 406 sbc, how much hp
mdross1
Re: AFR heads on 406 sbc, how much hp
Post by mdross1 »
Do appreciate the info will check out these heads and look into putting together a good reliable bottomend.Thanks Mike Ross
mdross1
Post by mdross1 »
What is the best bore stroke combination for a 440 inch small block? Want longevity
A Atwood
Post by A Atwood »
4.185 bore, 4" stroke. You would need a Dart little M or comparable. Also a professional to assemble the short/ longblock.
The 4" stroke will require some attention to detail by a pro. But with the right parts, would work very well.
ARN
www.atwoodperformance.com
mdross1
Post by mdross1 »
This probably will be my last go round so will be looking for an aluminum block,would really like to build a 454".Putting together plans for two different setups,one with SB2 topend easily getting into the 750/800hp range,the other with conventional setup getting into the 650 hp range.Considerations fitment into bike and exhaust.Both will work SB2 will require lifting gas tank and custom built headers,the other way is a bolt in.
A Atwood
Post by A Atwood »
mdross1 wrote:,would really like to build a 454".
Are you now talking Big Block?
If thats the case, build a 565. 800 horse would be a piece of cake. Extremely reliable, and mild enough to drive every day.
You really need to decide which direction you want to take this project before anyone can be of real help to you.
ARN
mdross1
Post by mdross1 »
Understand the confusion,As I said this motor is in the first stages of finding out what can be built and small blocks are new to me.Been building big blocks for a lot of years.So there is a learning curve.I now know I can bolt together most any size small block with SB2 topend and get into 800hp,a 15 or 18 degree topend and get into 700 hp,a good set of say AFR 220's and get into 600hp.The SB2,15 and 18 degree require special exhaust headers,also the SB2 topend would require a gas tank raise of who knows how much, a lot to consider.Before I start ordering parts have to decide which will be the best way for me to go.Because of the issues related to the SB2,15 and 18 degree motors need to look into big inch small blocks,and see just how much can be wrung from one of those.
So far have talked to SB2 people, AFR techs, JE pistons,Comp Cams,trying to get up to speed on what combinations work and work reliably. Thanks for bearing with me.For now looking into a big inch small block and know you can get them out to 488"
Orr89rocz
Post by Orr89rocz »
There are guys making 700+ hp with regular 23 deg heads....it is possible
mdross1
Post by mdross1 »
Sure would like to talk to these guys it would make life a lot easier.How do I get in touch with them?
Joel Dubose
Post by Joel Dubose »
Your talking to one...lol
JDE Heads & Manifolds
I'm WD with AFR,Edelbrock and many other parts and castings suppliers.
JDE has port programs In popular castings for performance uses, If you would like a port designed for your project contact me 704-658-6951
mdross1
Post by mdross1 »
Joel Dubose wrote:Your talking to one...lol
Hey Joel,Is there any chance you would pass on some of your experience,and what parts you chose to get into the 700hp area? What are you running for cubic inches?This motor I want to build will have an aluminum block,want to save as much weight as I can,it's going in a motorcycle.Mike Ross
mdross1
Post by mdross1 »
Been working the rotating night shift,head is in the fog.Went back and read the past postings,all set on your set up Joel.
Joel Dubose
The company that I worked for built some 23* 9/1 engines. These were for a busch north engines. We bought a head that flow 360 cfm. It was a 356 ci engine , big bore short stroke. While testing the engine on the dyno , we put a cup style carb on it. About a 1000 cfm carb. And made a few pulls. It made 680 HP. That was at 9/1 cr. So add some compression and your there. We also did a dirt track late model that we used some heads that I ported. Its been a while but I think that I had the heads flowing around 375 cfm. It made 700 HP. It was also a 358 ci engine. The really large ci engines tend to make power early so they become head limited to early in the rpm to make the most power. If you built a large ci engine you would need to increase cam size and watch your airflow to make sure that power doesn't occurs to early. Take for example 550 fp @ 4200 rpms vrs 500 fp @ 6500 rpms do the math and you'll see where I'm coming from.
mdross1
Post by mdross1 »
Joel Dubose wrote:The company that I worked for built some 23* 9/1 engines. These were for a busch north engines. We bought a head that flow 360 cfm. It was a 356 ci engine , big bore short stroke. While testing the engine on the dyno , we put a cup style carb on it. About a 1000 cfm carb. And made a few pulls. It made 680 HP. That was at 9/1 cr. So add some compression and your there. We also did a dirt track late model that we used some heads that I ported. Its been a while but I think that I had the heads flowing around 375 cfm. It made 700 HP. It was also a 358 ci engine. The really large ci engines tend to make power early so they become head limited to early in the rpm to make the most power. If you built a large ci engine you would need to increase cam size and watch your airflow to make sure that power doesn't occurs to early. Take for example 550 fp @ 4200 rpms vrs 500 fp @ 6500 rpms do the math and you'll see where I'm coming from.
Joel,whose heads did you use on those pulls.There are a lot of choices,some I have read flow near 400cfm.My plan to this point is an aluminum block approx 427ci, would really like to use a head that has the standard exhaust bolt pattern,Super Victor intake.Once the block and heads I decide on are here will call Comp Cams,then see about getting a dbl pmper.Mike Ross
maxracesoftware
Vendor
Post by maxracesoftware »
Orr89rocz wrote:There are guys making 700+ hp with regular 23 deg heads....it is possible
we are making honest, conservative 800+ HP with Dart Pro 1's 23 deg Heads unwelded, no epoxy,
single 4-barrell ProSystems Dominator on Edelbrock SuperVictor manifold
4.187x4.000=440.6cid
Peak TQ = 589.3 @ 6600
Peak HP = 807.5 @ 8300
600 rpm/sec
GRP 5.880 C-C alum rods
Diamond Pistons
14:1 CR Torco 118 Red
Cam Motion solid roller
1.80/1.80 Jesel Rockers
new Billet Fab oil pan 8.250 depth full kickout
Star Vac Pump 4-vane std
ProSystems Carb
.025/.025
cranking psi= 212
40 from 38
Q-16 race gas
1994 Beretta 2450 lbs w/Driver
best so far 8.41 ET @ 159+ mph on just Motor
ran this ET on TV Show Passtime at No Problem Raceway
60 FT= 1.089
330 Ft= 3.110
660 Ft= 4.797 - 145.83 MPH
1000 Ft= 6.251
1320 Ft= 7.493 at 186.36 MPH
4.30 gear
2450 lb
with 325 HP NOS
700 HP with a 4.185x4.000 combo would be pretty reliable
MaxRace Software
https://www.maxracesoftwares.com
maxracesoftware
Vendor
MaxRace Software
