Page 1 of 1
400 SBC hi nickel identification
Posted: Sat Jul 16, 2011 4:48 pm
by BrazilianZ28Camaro
Hello friends
I just need some info about how to ID a hi-nickel 400ci factory block.
I've been reading different advises, so I'm confused.
There's a code or sign in the block to look for?
Hope the knowledgeable members here can shed some light
Thanks in advance!
Re: 400 SBC hi nickel identification
Posted: Sat Jul 16, 2011 5:53 pm
by ProPower engines
From what I have seen the 509 block has the rectangle bars cast in the valley meaning higher nickel content in the casting.
The blocks I have machined have had a shinier finished machined appearance and were slightly harder to hone.
There may me others with more nickel but a basic rule to go by is the 400 blocks had way more nickel to make them stronger because of there design.
Posted: Sat Jul 16, 2011 9:40 pm
by Jginger
under the timing cover will be casting numbers cast in the block,
like 010 or 020 or both.
Posted: Sat Jul 16, 2011 11:02 pm
Great info friends!
My 400ci #509 two bolt block have the rectangles in the lifter valley and "010" on the timing cover area.
Guess I'm lucky !!!
