what are the best water and oil temperatures for drag racing
I have heard different opinions and would like to know what the best temperatures are?
There isn't one temperature for every application.
The cooling system takes away heat (power) from the combustion chamber and if you have too efficient of a cooling system without a thermostat you can be loosing power. If the cooling system does not work properly though you can run into detonation problems if your motor gets too hot.
Oil temperatures are different though. Sure the oil takes away some heat, but not as much as water would. The hotter oil gets the more it degrades which means that your motor is going go to be seeing metal on metal friction at some point if oil temps are not checked upon. Most oil manufacturers have recommendations for not to exceed X temperature and I'd try to stay as low as possible as long as your motor can still be properly lubricated.
[i][b]Making Fast Cars Faster[/b][/i]
[url=http://www.didraceengineering.com/][b]D.I.D. Race Engineering[/b][/url]
Well, in a perfect world you would have a cold induction system and a hot engine.
It depends on the application though. If you're bracket racing you should just run the engine at a 180 degree area operating tempature every time so it's consistant.
If you're shooting for maximum performance, you want hot oil, and a cold induction which for most people means a cold engine.
Uratchko Racing Engines
248-755-5556
248-755-5556
Dmatulion,
There are hundreds of opinions on this. However the fact remains, (in this question of a drag engine) the cooler you can keep your engine, the better off you'll be in many ways. One is you'll make more power! Heat is the enemy of performance. Stop warming up your engine in the pits. if its during the summer the water temp is already 100+ degrees in your engine, so start her up just to get the oil up to proper temp and go racing.
Of course a circle track engine will be totally differant for obviouse reasons. Running 50+ laps will put your best cooling system to the test. For good informative reading check out an article by David Reher. Teck talk article #25 on their web-site. It will put alot of thoughts into another perspective.
Mike Theroux
www.mikesportingservice.com
Mike Theroux
Mike Theroux
www.mikesportingservice.net
There is never enough time!!
- New Member
