Hello,
I am looking for stamped steel (stock appearing) 1.6 ratio rocker arms for a Pontiac 350 engine. (or 400, all the same).
Can be stock or aftermarket.
Will any particular 'other' brand work? BBC?
ProPower engines wrote:250 l6 CHEVY.. They are 1.7 and 3/8" stud. If stud diameter is optional then use BBC rockers. There is a bit of rocker stud alignment to over come but no big deal.
There is also after market"stock appearing rockers" on the market and some with roller tips if alowed but spring pressures on a pontiac can be changed easy if stock diameter springs are required
racerx1622 wrote:ProPower engines wrote:250 l6 CHEVY.. They are 1.7 and 3/8" stud. If stud diameter is optional then use BBC rockers. There is a bit of rocker stud alignment to over come but no big deal.
I have not been able to find any after market "stock appearing rockers" for Pontiac in 1.6 ratio.
If you know a source I would be very grateful.
Users browsing this forum: Bing [Bot], Cubic_Cleveland, Exabot [Bot], Google [Bot], Sir Yun, Yahoo [Bot] and 11 guests
