600 HP LS engine carb section
- New Member
Re: 600 HP LS engine carb section
No idea why I am responding to this as others have seen the point. You two guys cannot see the forest for the trees, so let me play Mr. Obvious.
1. I tune on customers carbs.
2. I get feedback from the tuning session.
3. I take the data that I learn and employ it in other similar builds.
4. I make minor adjustments based on their variances (altitude, header size, stall converter etc...).
Now thats why so many folks can bolt them on the way I hand them to them and cannot improve it.
I am working off 15 years of data. I have a fully computerized reference system to recall thousands and thousands of customer builds and their feedback. As a result, I have a pretty good track record of nailing it. You get that from being hands on and being organized. Sure we miss, but Troy you are working off 32 years of data and you EXPECT to miss it? Nice.
OK, I gotta get back to work, I suspect Troy you should do the same and maybe improve your organizational skills and get a little more "hands on" so your product can be a little better when it rolls out of your shop. You should not EXPECT to miss it. Thats not what these folks are paying for.
Patrick James
PRO SYSTEMS
Patrick James
PRO SYSTEMS
Patrick, is it a lack of organization and experience on my part or that I am pushing the performance and carburetor design envelop outside the data pool of prior parameters?
I could do as you've expressed and build the same thing time and time again, but I don't. You keep making my point about taking the easy path rather than optimizing That's fine, not everyone wants to optimize their combination, some just want bragging rights.
I'm really in this because I love the technology and I want to see how far we can take the internal combustion engine.
Troy Patterson blog tmpcarbs.blogspot website TMPCarbs.net Engine Professionals Magazine's TMP Tuning article, pg. 44
- jmarkaudio
I can see quite well over the trees, and know to step over the BS as well.
Mark Whitener
www.racingfuelsystems.com
____
____
In defense of Patrick, I really don't think you need 500 different carbs for 500 different sbc Camaro's. There have been huge improvements on blow through carbs recently, but how much more can be done to the naturally aspirated carb. I looks like the new innovations are just repeats of things that have been done before. Are we nearing the end for HP gains on the carb? Guys are removing old poorly tuned carbs and replacing it with the trick of the week carb, picking up 20 HP and claiming it as the best carb on the market when they could have tuned their old carb and seen the same gain.Troy Patterson wrote:Patrick, is it a lack of organization and experience on my part or that I am pushing the performance and carburetor design envelop outside the data pool of prior parameters?
Actually, no and no. There are improvements being made all the time, and an "old" carb won't have the hard parts to allow a similar tune. The "old" or box stock carburetors have a limited range of venturi and throttle bore combinations too, so you really can't use what'll work best in most cases.
http://www.jdrperformance.com
417-859-2353
417-859-2353
I agree with JDR, there appears to be no limit to making gains with the internal combustion engine and carburetors.
Maybe you're right. I'm certainly no carb expert. It just seems to me that there would be more advancement in injection than we have seen. Like a completely redesigned injector or different placement or multiple nozzles each doing something different. Sorry, I think I drank too many cups of coffee today.Troy Patterson wrote:I agree with JDR, there appears to be no limit to making gains with the internal combustion engine and carburetors.
I haven't had enough cups of coffee todayavengerengines wrote:Maybe you're right. I'm certainly no carb expert. It just seems to me that there would be more advancement in injection than we have seen. Like a completely redesigned injector or different placement or multiple nozzles each doing something different. Sorry, I think I drank too many cups of coffee today.Troy Patterson wrote:I agree with JDR, there appears to be no limit to making gains with the internal combustion engine and carburetors.
Ignoring diesels and one of the earliest F.I. gasoline cars, the 1954 Mercedes Benz, recent uses of direct gasoline injection would meet your criteria...avengerengines wrote:Maybe you're right. I'm certainly no carb expert. It just seems to me that there would be more advancement in injection than we have seen. Like a completely redesigned injector or different placement or multiple nozzles each doing something different. Sorry, I think I drank too many cups of coffee today.Troy Patterson wrote:I agree with JDR, there appears to be no limit to making gains with the internal combustion engine and carburetors.
Mr James, I bought one of your carbs last year, took a long while for my new cylinder heads to be sent but I have them now so I am screwing it together and dyno tuning shortly.
Specs are, 434 4.155 x 4 warhark , MAST 12 degree inline heads exhaust has been touched up a little,401cfm 3.28" choke, 2.25" valve, 5 angle seats , 14.0:1 , 273-289-110+0, RX drag lobes, MAST intake and SV1 see how we go with it.
Hyd rollers are for GIRLS---The higher the rocker ratio, the sooner the valves will float
JOE SHERMAN RACING
JOE SHERMAN RACING
