Page 1 of 3
Heads for 434 SBC??
Posted: Thu Mar 24, 2011 5:31 pm
by 12scndz
We have a 3100#, quarter mile only backhalved/ladder bra 1970 Camaro. We're running a 4800 stall with a transbrake 400, and 4.11 gears. For 4 years, I drove this car with an 11.5:1 flat-top 386 (destroked 400) with a mild solid roller. I ran 10.83@ 125 MPH with that combo. We now have a Little M based 434 small block with 14.5:1 compression and 278-288 @ .050" - .727" solid roller cut on a 109 LSA.
My question is about head choice. We used a set of 230 CC Dart Iron Eagles on the 386 with 64 Cc chambers and 2.08"-1.60" valves. We had 4.88's in the car then and I shifted at 7600 RPM's. The engine builder sells this complete 434 with AFR 227 heads on it and makes 695 HP with this combo and a single Dominator.We're not real concerned with the weight of the iron heads, but how much HP will they cost us? This is just a weekend play toy, and we're not looking to be the fastest out there. We're using a Weiand tunnel ram with 2 Predators and 1 3/4" open headers. I'd like to see 10 teens out of this thing. Should these iron heads be enough to get me there?
Thanks,
Frank
Re: Heads for 434 SBC??
Posted: Thu Mar 24, 2011 6:37 pm
by bigjoe1
What ever else you do, DO NOT use the AFR 235 heads=If you do, you will sorry
JOE SHERMAN RACING ENGINES
Posted: Thu Mar 24, 2011 7:10 pm
by alan johnson
because the afr 245 head would be a better choice
Posted: Thu Mar 24, 2011 8:25 pm
by BrazilianZ28Camaro
bigjoe1 wrote:What ever else you do, DO NOT use the AFR 235 heads=If you do, you will sorry
BigJoe,
I'm curious why the AFR 235 is a poor choice for that engine...care to expand a little?
Posted: Thu Mar 24, 2011 8:45 pm
by CNC BLOCKS
That big of cubic inch you should be looking at the 18 degree stuff!!!
Posted: Thu Mar 24, 2011 8:55 pm
by bigjoe1
i JUST WANTED TO SEE IF ANYONE IS PAYING ATTENTION I use and sell them all the time.. VERY GOOD CHOICE= You can make 750 to 830 horsepower with one big carburetor
JOE SHERMAN RACING
Posted: Thu Mar 24, 2011 9:04 pm
by 12scndz
Joe,
Thanks for the advice. I've followed your work for years. In your opinion, will the 230 Iron Eagles work OK for this combination? WE already have these heads that ate fresh from the machine shop. They have new valves, guides, seal, and valve job. So, we've got a set, ready to bolt on. I just don't want to let go of $1800-$1900 if I'm only going to see 10-15 HP. We're the "little guys" that just want fast play toys to have fun with.
Frank
Posted: Thu Mar 24, 2011 9:05 pm
by supergass
BrazilianZ28Camaro wrote:bigjoe1 wrote:What ever else you do, DO NOT use the AFR 235 heads=If you do, you will sorry
BigJoe,
He cant say anything about the AFR heads without a couple of trolls that go around looking for trouble start disputing everything he says. They have ruined many many threads on this site with there drama queen ways! Oh that AFR 235 is a great head, you must use shaft mount rockers so add in about another 1000 to 1200.00. That 434 will need all that head can deliver! Good luck, you will love it!
Posted: Thu Mar 24, 2011 10:00 pm
by JBV-HEADS
Both the AFR heads mentioned are very good. I see the major problem as being the but-plug header you have. Go to a 1.875 header with your same setup and a mild bowl job on the heads you have. You might make what you are looking for at the least cost. But those AFR's or any head doing 320+ cfm at .600-.650 and you probably will be happier. Good luck,
Joe
Posted: Thu Mar 24, 2011 10:33 pm
by 1bossnova
bigjoe1 wrote:i JUST WANTED TO SEE IF ANYONE IS PAYING ATTENTION I use and sell them all the time.. VERY GOOD CHOICE= You can make 750 to 830 horsepower with one big carburetor
JOE SHERMAN RACING
Joe can you share a dyno sheet on one of these "830 hp" single 4 engine's??? thats some awesome power
Posted: Thu Mar 24, 2011 10:58 pm
by bbmachine
How'd ya get the cam without knowing whitch heads you we going to use?
Posted: Thu Mar 24, 2011 11:20 pm
by bigjoe1
When someone spends a great deal of money for one of my engines, then they would put the results on the internet if they wanted everyone to know about it.
Posted: Fri Mar 25, 2011 1:35 am
by bigcam406
i totally agree
Posted: Sat Mar 26, 2011 11:54 am
by ricks57
Joe doesn't exaggerate. How about 813 HP out of only 400 cubic inches!!
http://www.hotrod.com/techarticles/engi ... index.html
Rick
Posted: Sat Mar 26, 2011 2:40 pm
by pdq67
Joe,
I pissed Tony Mamo off big-time a while back when I asked him to make a stock SBC head-bolt pattern head that had the new, (back then), LS- ports in it because to this day, it's the LS- head's ports and valve angles that make their great power and nothing else worth mentioning.
Tony has since come out with their high-zoot 23 degree head to probably counter what I'm talking about. BUTat a price, imho..
Please talk about this with all of us here IF you want to. Much appreciation if you do, but no big deal if you don't.
Thanks for any consideration.
