Heads for 434 SBC??
12scndz
Heads for 434 SBC??
Post by 12scndz » Thu Mar 24, 2011 5:31 pm
We have a 3100#, quarter mile only backhalved/ladder bra 1970 Camaro. We're running a 4800 stall with a transbrake 400, and 4.11 gears. For 4 years, I drove this car with an 11.5:1 flat-top 386 (destroked 400) with a mild solid roller. I ran 10.83@ 125 MPH with that combo. We now have a Little M based 434 small block with 14.5:1 compression and 278-288 @ .050" - .727" solid roller cut on a 109 LSA.
My question is about head choice. We used a set of 230 CC Dart Iron Eagles on the 386 with 64 Cc chambers and 2.08"-1.60" valves. We had 4.88's in the car then and I shifted at 7600 RPM's. The engine builder sells this complete 434 with AFR 227 heads on it and makes 695 HP with this combo and a single Dominator.We're not real concerned with the weight of the iron heads, but how much HP will they cost us? This is just a weekend play toy, and we're not looking to be the fastest out there. We're using a Weiand tunnel ram with 2 Predators and 1 3/4" open headers. I'd like to see 10 teens out of this thing. Should these iron heads be enough to get me there?
Thanks,
Frank
bigjoe1
Show Guest
Show Guest
Re: Heads for 434 SBC??
Post by bigjoe1 » Thu Mar 24, 2011 6:37 pm
What ever else you do, DO NOT use the AFR 235 heads=If you do, you will sorry
JOE SHERMAN RACING ENGINES
alan johnson
Post by alan johnson » Thu Mar 24, 2011 7:10 pm
because the afr 245 head would be a better choice
BrazilianZ28Camaro
Post by BrazilianZ28Camaro » Thu Mar 24, 2011 8:25 pm
bigjoe1 wrote:What ever else you do, DO NOT use the AFR 235 heads=If you do, you will sorry
BigJoe,
I'm curious why the AFR 235 is a poor choice for that engine...care to expand a little? [-o<
Last edited by BrazilianZ28Camaro on Thu Mar 24, 2011 9:00 pm, edited 1 time in total.
'71 Z28 Pro-Street Camaro
Pump gas -T-ram - All motor SBC 427"
3308 lbs- leaf spring/Caltrac Car
29x10.5 Hoosiers
New best 1/8 mile ET
1.45 60' / 4.12 330' / 6.38@110mph :D
CNC BLOCKS
Post by CNC BLOCKS » Thu Mar 24, 2011 8:45 pm
That big of cubic inch you should be looking at the 18 degree stuff!!!
Website is up and running
Machine shop tour
Monthly Specials
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 » Thu Mar 24, 2011 8:55 pm
i JUST WANTED TO SEE IF ANYONE IS PAYING ATTENTION I use and sell them all the time.. VERY GOOD CHOICE= You can make 750 to 830 horsepower with one big carburetor
JOE SHERMAN RACING
12scndz
Post by 12scndz » Thu Mar 24, 2011 9:04 pm
Joe,
Thanks for the advice. I've followed your work for years. In your opinion, will the 230 Iron Eagles work OK for this combination? WE already have these heads that ate fresh from the machine shop. They have new valves, guides, seal, and valve job. So, we've got a set, ready to bolt on. I just don't want to let go of $1800-$1900 if I'm only going to see 10-15 HP. We're the "little guys" that just want fast play toys to have fun with.
Frank
supergass
Post by supergass » Thu Mar 24, 2011 9:05 pm
BigJoe,
He cant say anything about the AFR heads without a couple of trolls that go around looking for trouble start disputing everything he says. They have ruined many many threads on this site with there drama queen ways! Oh that AFR 235 is a great head, you must use shaft mount rockers so add in about another 1000 to 1200.00. That 434 will need all that head can deliver! Good luck, you will love it!
JBV-HEADS
Post by JBV-HEADS » Thu Mar 24, 2011 10:00 pm
Both the AFR heads mentioned are very good. I see the major problem as being the but-plug header you have. Go to a 1.875 header with your same setup and a mild bowl job on the heads you have. You might make what you are looking for at the least cost. But those AFR's or any head doing 320+ cfm at .600-.650 and you probably will be happier. Good luck,
Joe
1bossnova
Post by 1bossnova » Thu Mar 24, 2011 10:33 pm
bigjoe1 wrote:i JUST WANTED TO SEE IF ANYONE IS PAYING ATTENTION I use and sell them all the time.. VERY GOOD CHOICE= You can make 750 to 830 horsepower with one big carburetor
JOE SHERMAN RACING
Joe can you share a dyno sheet on one of these "830 hp" single 4 engine's??? thats some awesome power =D>
Bryce Mulvey
Dr. J's Performance
www.j-performance.com
bbmachine
Post by bbmachine » Thu Mar 24, 2011 10:58 pm
How'd ya get the cam without knowing whitch heads you we going to use?
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 » Thu Mar 24, 2011 11:20 pm
When someone spends a great deal of money for one of my engines, then they would put the results on the internet if they wanted everyone to know about it.
bigcam406
Post by bigcam406 » Fri Mar 25, 2011 1:35 am
i totally agree :)
ricks57
Post by ricks57 » Sat Mar 26, 2011 11:54 am
Joe doesn't exaggerate. How about 813 HP out of only 400 cubic inches!!
http://www.hotrod.com/techarticles/engi ... index.html
Rick
Post by pdq67 » Sat Mar 26, 2011 2:40 pm
Joe,
I pissed Tony Mamo off big-time a while back when I asked him to make a stock SBC head-bolt pattern head that had the new, (back then), LS- ports in it because to this day, it's the LS- head's ports and valve angles that make their great power and nothing else worth mentioning.
Tony has since come out with their high-zoot 23 degree head to probably counter what I'm talking about. BUTat a price, imho..
Please talk about this with all of us here IF you want to. Much appreciation if you do, but no big deal if you don't.
Thanks for any consideration.
