I contend that this is absolutely true, at first. But as time progresses and the two materials heat soak and the cooling system heat soaks, the difference in heat transfer speed difference to the cooling systems decreases and the two different power outputs of otherwise identical engines becomes less of a difference.ap72 wrote:You will see a significant difference at WOT steady state, the heat transfer of the aluminum will cause a lot more heat dissapation into the cooling system, lowering the temp inside the chamber.F-BIRD'88 wrote:Aluminum conducts heat (a change in heat) faster than cast iron.
But hot aluminum is just as hot as hot cast iron. So when a motor goes WOT it starts making heat. The alumnium sucks the heat away at first (to the cooling system) but once heat soaked the cast iron catches up. Once you let off the gas the cast iron head retains the heat longer. So the aluminum head has a short period where it will have a small knock threshold advantage and small power diference. But the two materials even out eventually. Hot is hot.
So for drag racing it has a small brief advantage (or disadvantage depending on how you look at it) and can tend to tolerate a bit more cr.
Once running WOT steady state there is no difference.
Many people make way too much of any practical difference.
In a steady state WOT dyno test comparison, to prove one way or the other, all the other factors would have to be controled.
I contend that at first there is a big difference but the difference gets a good bit less over time.
