HELP!!!...Holley metering block ID
Postby n2oracer » Fri Jan 28, 2011 4:02 pm
A guy brought me a box of Holley carbs that have been disassembled. There are several carbs there : a couple of 750 mech, 600 vac, and a couple of 450 mech. Plus spare parts gathered over the years. I need help matching the metering blocks to the correct carbs. I couldn't find the info on Holley's site. Found part #, but not the stamped ID numbers. Here is what I have.
11166 3
9970 3
6541 4779
11180 3
11038 6
4100
1947 3
n2oracer
Re: HELP!!!...Holley metering block ID
Postby DrillDawg » Fri Jan 28, 2011 4:40 pm
anything 4779 is 750 DP, check the jets in the diff. blocks and see if you can match the jet size to carb size, that should be in the book.
DD
DrillDawg
Postby n2oracer » Fri Jan 28, 2011 5:39 pm
No jets or PVs
n2oracer
Postby jmarkaudio » Fri Jan 28, 2011 9:24 pm
The 4779 is a 750 DP block, the 11180 3 block is from an early 4781 850 DP, two emulsion bleed metering block. I use those for an inexpensive 3 to 2 circuit Dominator conversion.
Mark Whitener
____
jmarkaudio
Postby Ron Miller » Sat Jan 29, 2011 12:57 pm
Call Holley Tech Department. They will help you with all your numbers. They even can tell you the application from the numbers, jet size, etc.
Ron Miller
Ron Miller
Postby JDR Performance » Mon Jan 31, 2011 9:01 am
jmarkaudio wrote:The 4779 is a 750 DP block, the 11180 3 block is from an early 4781 850 DP, two emulsion bleed metering block. I use those for an inexpensive 3 to 2 circuit Dominator conversion.
11180-3 is for a 750. Look at the pvcr size.
JDR Performance
Postby BLACK BART » Tue Feb 01, 2011 2:58 am
My records show the #11166 block to be a primary block for a 4779DP.
The #6541 and #11180 blocks to be primary blocks for a 4779DP.
The #4100 block is a secondary conversion block to convert a model 4160 to a model 4150.
I don't have anything on the other numbers, but I hope what I listed helps. CJ
Arguing with someone on the Internet is like participating in the Special Olympics...Even if you win you are still retarded!
BLACK BART
Postby JDR Performance » Tue Feb 01, 2011 1:03 pm
11166 is a secondary metering block, and will not be drilled and tapped for a power valve.
JDR Performance
Postby jmarkaudio » Tue Feb 01, 2011 3:07 pm
I'll have to look, but my blocks come bare, without any plugs in the wells, IFR's, and I believe PVCR's. I asked for 850 blocks, may be what they use at BLP and modify as needed. Either way they are an early 2 e-bleed block and should work for any DP with the right IFR's, PVCR's and jets.
Mark Whitener
____
jmarkaudio
Postby JDR Performance » Tue Feb 01, 2011 3:35 pm
The pvcr is drilled to size for a 750. If they're complete metering blocks like the ones he's got, the ifr will be for a 750 also, and will be smaller than they would be for an 850. For what you're doing with them they're fine.
JDR Performance
Postby n2oracer » Tue Feb 01, 2011 4:19 pm
Thanks guys. That info seems to support whats here as I have 4779-6 and 80779. Both 750's.
n2oracer
Return to Engine Tech
Who is online
Users browsing this forum: 383hoopty, 3V Performance, BrazilianZ28Camaro, F-BIRD'88, Google [Bot], hharr93, ingram, jdavis, Pappy, rickyracer, Schurkey, Top452 and 20 guests
