milling intake manifolds
Re: milling intake manifolds
Bump for some information help please.
I have a MarkIV BBC that has had some extensive head work done. The heads have been flat milled .050 this time around to keep compression up to 13.5.
The heads are torqued down to the block. With a .060 intake gasket on each side the intake is mismatched with the heads.
What I want to know is there a way to measure the amount of material that needs to be milled off the intake??????
So if the intake is sitting on the China wall, with no gaskets, and I slide the intake over against one head, can the measurement between the opposite head and intake be used to determine the amount to be milled????????? If this was a stock deck and head surface would that gap be .120 doing this?
Thanks for any input.
Tom
Tom
1.34 9.42 @ 142.41 / 1.28 5.96 @ 115.00 @ #3251 Better in 2023
427 BBC by S&S Speed Center, AFD, Enderle MFI by Spud Miller
Sepanek Racing T400, Dynamic converter, Autoweld, Santhuff, Smith Racecraft,
Dick Fords Body Shop, Trackside Products,
- Dave Koehler
You will be better served to mill the manifold side of the heads despite the hassle.
Otherwise you wind up with a manifold useless for anything else.
Thank you for the Wallace calculator. I don't see big block, but it should be the same as SBC. I will run some numbers through it.
Problem is, these heads have been cut before lightly, but I don't know what the total amount adds up to.
69427 wrote:Thank you for the Wallace calculator. I don't see big block, but it should be the same as SBC. I will run some numbers through it.
oops.. sorry for the quick fly by.. didn;t even notice that. lol
Then you'd need to trig it out or use a protractor. Would still need to know the amount milled but maybe this would help as well?
http://www.crankshaftcoalition.com/wiki ... nder_heads
The heads where milled but not enough. I suspect the manifold China wall will need to be done any how.Dave Koehler wrote:You will be better served to mill the manifold side of the heads despite the hassle.
- Wolfplace
Try these
https://www.hastingsmfg.com/ServiceTips ... _heads.htm
http://www.goodson.com/blog/2012/01/13/ ... e-milling/
From Jeffery Diamond's site Victorylibrary.com.
http://victorylibrary.com/mopar/intake-mill-c.htm
BB is 1 to 1 for the intake face, China wall would be the same as any 90° head. ford, Pontiac etc. or 1.4
To answer your question, yes if you pull the intake against one head the distance on the other side will be the amount needed to correct minus the two gaskets of course but you need to have the intake at the correct height first or the numbers will be incorrect because as the intake lowers the gap decreases so,,,
If it is sitting on the china wall before the ports/ bolt holes align you need to remove some off the bottom before you will know what if any to take off the faces
If at or below the ports you are good, measure & cut so the gaskets fit then get enough room at the ends for some sealant
Don't forget to leave enough for when the gaskets compress you obviously don't want the intake sitting on the block,,,,
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
A tour of my shop
The Dyno
John Wayne
Wolfplace wrote:69427 wrote:Thank you for the Wallace calculator. I don't see big block, but it should be the same as SBC. I will run some numbers through it.
Try these
Mike
Thank you for taking the time to post that. I have some figuring to do.
And your signature fits this problem:
John Wayne
Whats wrong with using offset dowels to move the manifold face of the head away from the intake...same as milling it correct?
In my case it would throw the chamber out of whack with the bore.cgarb wrote:Whats wrong with using offset dowels to move the manifold face of the head away from the intake...same as milling it correct?
Off set dowels creates a completely different "Bag of Worms"
I have used the same method/numbers Mike Lewis has posted.
The old VN charts and info will not get you in trouble.
I had a chart that came with my first 85B. It finally turned to dust, but
it used the same calculation method that Van Norman used.
On heads that I've done a sever angle mill on I always do the heads, not the intake.
I have not figured out a real easy way to do them accurately, but cut and try.
If I'm doing BB I usually do a 1-1 as a starting place. On a 10 deg SBC I use a 1.2 factor.
I never try to do the cut in one step. I cut at least 2 times to make the "Fit"
That is just one of the reasons I've always worked slow.
Adger Smith
903 794 7223 shop
903 824 4924 cell
adgersperf@aol.com e-mail
903 794 7223 shop
903 824 4924 cell
Adger Smith wrote:Off set dowels creates a completely different "Bag of Worms"
Thank You for the reply Adger
Well it looks like a .090 mismatch after some creative measuring.
Thanks
Thanks
A 'no math' approach is to use shims/feeler gauges at each corner to space the manifold to achive alignment, then machine the head faces accordingly. e.g: perfect alignment occurs with 0.020" shims and the gaskets are 0.060" compressed, so mill 0.040" from each. (Of course this only works if the manifold aligns with more than zero shim thickness...)
Thank You MadBillMadBill wrote:A 'no math' approach is to use shims/feeler gauges at each corner to space the manifold to achive alignment, then machine the head faces accordingly. e.g: perfect alignment occurs with 0.020" shims and the gaskets are 0.060" compressed, so mill 0.040" from each.
I will use that to triple check what I have found before I commit.
Tom
