milling intake manifolds
jimjamm65
Post by jimjamm65 » Thu Jan 27, 2011 5:25 pm
what is the formula for milling the sides of a big block chevy intake manifold please.
Baprace
Re: milling intake manifolds
Post by Baprace » Thu Jan 27, 2011 8:50 pm
I have a home made spreadsheet and if I mill BBC head .050 then Intake face gets cut .035 so it's about 70%.
Wolfplace
Post by Wolfplace » Thu Jan 27, 2011 11:43 pm
jimjamm65 wrote:what is the formula for milling the sides of a big block chevy intake manifold please.
90° heads are 1 to 1
Formula courtesy of Master Panic
.707 ÷ (SIN (45 - intake face angle))
http://victorylibrary.com/mopar/intake-mill-c.htm
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
SchmidtMotorWorks
Post by SchmidtMotorWorks » Fri Jan 28, 2011 1:15 am
If you have 0.100 mismatch, take 0.100 from each side.
The manifold will drop 0.141.
Baprace
Post by Baprace » Fri Jan 28, 2011 4:43 am
I thought for sure I had duplicated the formula based on the dimension's I had found in the Chevy Power Book :oops:
I"ll have to check tomorrow to see where I screwed up. sorry for giving wrong info :oops:
jimjamm65
Post by jimjamm65 » Fri Jan 28, 2011 8:39 am
thanks for the information, guys. i appreciate it. jimjamm65
Baprace
Post by Baprace » Fri Jan 28, 2011 8:57 pm
This information is from Chevy Power book #6 for BBC milling can anyone check it out to see if it is correct.
Baprace
Post by Baprace » Fri Jan 28, 2011 9:08 pm
This information is from Chevy Power book #6 for SBC milling.
Wolfplace
Post by Wolfplace » Fri Jan 28, 2011 10:38 pm
The SB numbers are correct
I do not know where the BB numbers come from but they are wrong.
Could be empirical data just like I normally use 1 to 1 for a small block.
Even though I know it is not the correct number it works
Correctly done any angle other than 45° from vertical requires either more or less material removed from the intake surface to be "correct" & the multiplier is derived from the formula that I linked to by Mr Diamond (Panic)
Mike
A tour of my shop
The Dyno
John Wayne
Baprace
Post by Baprace » Sat Jan 29, 2011 2:58 pm
Wolf , thanks for the clarification.
SchmidtMotorWorks
Post by SchmidtMotorWorks » Sat Jan 29, 2011 4:10 pm
Here is the same model but adjusted for a 10 degree intake face like a gen-1 SBC
In this case to correct a 0.100 mismatch you remove 0.143 from each face, the manifold will drop 0.174
Wolfplace
Post by Wolfplace » Sat Jan 29, 2011 4:44 pm
SchmidtMotorWorks wrote:Here is the same model but adjusted for a 10 degree intake face like a gen-1 SBC
Jon
Explain the .143?
Would it not be .123
.707/.574
Mike
A tour of my shop
The Dyno
John Wayne
SchmidtMotorWorks
Post by SchmidtMotorWorks » Sat Jan 29, 2011 4:55 pm
I just make a parametric sketch, that way I avoid any possible mistakes in how I apply the trig triangles.
The CAD app just returns the values.
Intuitiveley 0.143 does seem high, I can double check it, in a couple of hours when I get back to the computer I did that on..
The trig way.
The intake face on a SBC is 35 degrees from horizontal
Tangent(35) = 0.7002 (opposite/adjacent)
1/0.7002 = 1.428
The mismatch is 0.1" so proportionally the correction is 0.1428 (rounds to 0.143)
Wolfplace
Post by Wolfplace » Sat Jan 29, 2011 8:09 pm
SchmidtMotorWorks wrote:I just make a parametric sketch, that way I avoid any possible mistakes in how I apply the trig triangles.
The trig way.
1/0.7002 = 1.428
Thanks, math is not exactly my strong point #-o
I have always used the difference from 45°, as in Jeffery's formula & it appears to be the same way the old Van Norman 570 broach manual showed it in their chart for different heads.
IE
SB
45-10=35
sin35=.574
sin45=.707
.707/.574=1.232
Mike
A tour of my shop
The Dyno
John Wayne
SchmidtMotorWorks
Post by SchmidtMotorWorks » Sat Jan 29, 2011 8:42 pm
I think tangent is the proper function rather than sine in this case.
