2 degrees could be .030" of clearance. My issue is the lack of stability. You also have spark timing to keep in mind. Not to mention if someone is buying a new timing set it should at least act new during the install.Dodge Freak wrote: Now if the chain is a bit loose but the cam timing is correct, what is the harm if the cam moves 2 degrees at high rpm's..would you really notice it power wise, I would think not.
I use a lot of Liberty sets with the adjustable billet gears. Even they are loose in short order. I have been changing out just the chain and the new chain fits nice. So the chain is at least part of the problem. They usually start out nice.
Back when it was a Dynagear set they were awesome.
Where do I buy the chain that Dynagear used???
