I didn't know what else could do it. Changing the cam made the problem disappear on each of the motors.
Were the cams straight? Were journal fit and finish OK? Drive tension too high?
Was the base circles the same? Was the lash adjusters changed? How about overall valve stem height inc. the lash caps changed? How was the pattern on the wear pad? Possible coil bind? Was the cam brgs. change to a different material? Any changes in oil to the cam brgs. There are others on this forum that can give you more insight to your problem, like Bill Jones. .....................Jerry, at that cam small radius how much material did you have to remove? How many holes? I'm having trouble imaging that? i would think heavy metal would have been better,along with some holes. I havent tried taking that much out at such a small correction radius.SchmidtMotorWorks wrote:I didn't know what else could do it. Changing the cam made the problem disappear on each of the motors.
Even though the cam only spins 1/2 engine rpm, would you want something in a race engine 20 grams out?
I don't!
Any rotating part whose center of mass is not collinear with its center of rotation should be balanced.
SchmidtMotorWorks wrote:Any rotating part whose center of mass is not collinear with its center of rotation should be balanced.
Nope, not always, it depends on the source of imbalance and how you plan to correct it.
If the object being balanced is flexible (like a cam is) and you are balancing it with modifications to the ends of the cam you have no reason to believe that you are reducing bearing loads and plenty of reason to believe that you are increasing them where you have added or removed metal to compensate for imbalance in a region of the body that will not be effected by change in balance to a timing gear.
I think the part of this that everyone is missing is that dynamic balancing of the entire body doesn't mean anything to the local balance of sections of the body. This is of critical importance when the body is flexible (as a cam is). The cam already bends more from loads from the lifter than it ever will from out of balance loads.
If you really wanted to do this right, you would have to cut the cam into pieces, balance those pieces then duplicate the changes on an intact cam.
I've done this on crankshafts until I figured out a way to determine the internal imbalance with other measurements.
However, I don't see the situation as being all that different from that of an externally balanced crankshaft. It too is flexible (although how flexible relative to the forces in play is open to debate) and yet millions of engines are balanced this way, just as proposed for the cam situation.
Users browsing this forum: Google [Bot], lonlon, PhilD, technicaltom, Yahoo [Bot] and 2 guests
