SchmidtMotorWorks wrote:Nope, not always, it depends on the source of imbalance and how you plan to correct it.Any rotating part whose center of mass is not collinear with its center of rotation should be balanced.
If the object being balanced is flexible (like a cam is) and you are balancing it with modifications to the ends of the cam you have no reason to believe that you are reducing bearing loads and plenty of reason to believe that you are increasing them where you have added or removed metal to compensate for imbalance in a region of the body that will not be effected by change in balance to a timing gear.
I think the part of this that everyone is missing is that dynamic balancing of the entire body doesn't mean anything to the local balance of sections of the body. This is of critical importance when the body is flexible (as a cam is). The cam already bends more from loads from the lifter than it ever will from out of balance loads.
If you really wanted to do this right, you would have to cut the cam into pieces, balance those pieces then duplicate the changes on an intact cam.
I've done this on crankshafts until I figured out a way to determine the internal imbalance with other measurements.
This does not refute balancing.
Simply, consideration should always be made, (with any rotor), to minimize the distance along the axis of rotation between the off centered mass, and the respective correction.
The example shown in Jon's image should be manfactured with the shaft on either side of the encentric, moved opposite the center of rotation from the "green" cam
Obviously, the red counterbalance is the worst possible senario,
yet imagine the shaft both with and also without the added "red" counterbalance spinning, in a free suspension without bearings to contain ampitude. The large encentric will cause movement of the axis of rotation even prior to sufficient rpm for flex to be an issue.
