Cam choice for 540 BBC Pump Gas Solid Roller
The build will be a pump gas 540 10.7 comp Canfield 315 full ported cnc heads from M2 ,a edelbrock 454r vic jr 850 dp or a 900 dp e85 carb 2 inch headers going into a full weight 69 chevelle 4000 stall converter Th350, 350 to 390 gear this will be a bracket car with 500-700 miles a year street use
- New Member
Re: Cam choice for 540 BBC Pump Gas Solid Roller
what RPM do you what to shift at? are thinking solid roller? mostly street use?
- superstreeter
- New Member
How many ponies do you need ? (how fast do you need to go) what is the weight w/driver.
I'm building a 540 right now, 315 heads,10.4 - 1 comp. edel. intake, dominator carb (1250,cause I like it.lol) and a Lunati s/roller cam, that is matched to the setup to keep as much comp, as possible for pump gas. shud make right around 700 hp, and run 10.10 in a 3000 car
8 sec street car
- superstreeter
- New Member
I might add,, the cam is around 255/263 - .680 lift, but I like the cam timing @.050.
8 sec street car
- CamKing
Can you post the flow numbers on the heads?
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
like to keep it 7000 rpm and below thinking 750-800 hp if possible car weight with driver 3800 ET i was shooting for mid to low tens maybe high 9s in perfect air
lift #
.200...156----103
.300....229....144
.400....289....183
.500....326....218
.600....353....244
.700....364....267
.800....370....282
lift #
.200...156----103
.300....229....144
.400....289....183
.500....326....218
.600....353....244
.700....364....267
.800....370....282
PIC OF CAMARO http://www.smugmug.com/gallery/5392657_US4EK#330124540_9jtuK
video of run
http://s8.photobucket.com/albums/a26/vet85us/Drag%20Racing%20Videos/?action=view¤t=Cork10_79-1.flv&refPage=&imgAnch=imgAnch6
video of run
- Wolfplace
Don't know much about E85 but those carbs look pretty small
I wouldn't consider anything less than an HP1000 for gas,,
Don't think you are going to see power to 7000 with those heads & intake on a 540 either or is that the highest you intend to turn it?
Why such low compression with E85?
Here are a couple on pump gas to compare to that I did recently with Pro Systems HP 1000's & Victor Jr's that were very well ported
http://www.chevelles.com/forums/showthread.php?t=257041
http://www.chevelles.com/forums/showthread.php?t=217968
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
A tour of my shop
The Dyno
John Wayne
- New Member
if you going with E85 Make the comp more like 12-1 and go with at least a 1000hp . the comp cam 11-800-9 looks nice for a street car.
Dedicated E85 engine, then you are leaving a lot of power on the table at 10.7 to 1 CR imho.
Please consider more like 13.5 or 14 to 1 CR unless you might have to burn 92 or 93 octane in it.
Oh, and btw, our mid Missouri winter E85 blend can be as low as E70 so you would need to make sure that you are buying real E85!
wolf that is the highest i intend to turn it the 10.7 comp will work good on the e85 and still work on 93 octane too, and i thought the holley 1000 hp carbs were only 850 with no choke horn, i had one and compared it against a regular 850 and that is what it was
video of run
video of run
- CamKing
Cam # R80444-82436-112
270/276@.050"
.444"/.436" Lobe Lift
112 LSA
270/276@.050"
112 LSA
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
