steel shim head gaskets.........
Re: steel shim head gaskets.........
Do the GM steel shim gaskets have a fire ring ??
Is the defect in what I see, or what I'm seeing with ?
No, just an embossed ring around the bore. Not a separately-crimped-into-place fire ring like a composition gasket.
There are embossed ridges around all the water passages as well. The gasket material is springy, and the ridges spring-load themselves against the mating surface.
BTW, the GM factory steel shim gaskets won't work with the "light weight" heads, nor with some of the aftermarket heads. The water passages/core holes moved around past the edges of the embossed areas on the gasket.
Will the gasket mentioned from CV products work with those heads?
- BrazilianZ28Camaro
I did that too in my old 67' 283 decks, but used a " rectangular orange stone" (Excuses for lack of a better term. )instead of file.pdq67 wrote:
You can use a fine straight cut triangle file and very gently go from head-bolt hole to head-bolt hole and feel her clean up and become smooth/flat, BUT this is an old "feelie" deal by me!! Works fine once you get the feel down and watch the decks change from rust/cruddy to shiny metal oh so gently.
After , I used a square section of High speed steel (HSS) bit to check the flatness. No leaks so far!
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
NEW BEST ET
Fel-Pro #1094 = 4.100" x .015" 3.2cc rubber coated embossed steelap72 wrote:Can I get the part number for those gm shims for 8 bucks? What's the thickness on those?
Pete Graves
CPMotorworks,Inc.
Custom Engine Machining
CPMotorworks,Inc.
- New Member
retorque...... retorque..... retorque. pain in the ass, but..... go hard or go home.
Used them years ago on oval track motors.The trouble I had was after 10 races or so they would leak a small amount of pressure in to the water jacket on the power stroke.This would force a little water out, by the end of the race the car would be hot.100 psi on a leakdown tester would not show this leak.I found it by seeing carbon tracking on the gasket.
If you type fast it doesn't seem like a big problem but when your 20 years old,middle of august and don't have much money its a big deal.
A couple months ago I started a post about the need of retorque shim heads gaskets...my doubt appeared because the steel have a very small compressibility ,maybe none considerable, compared to a conventional gasket. This is the answer BIGJOE reply:Small block guy wrote:retorque...... retorque..... retorque. pain in the ass, but..... go hard or go home.
Steel shim head gaskets DO NOT need to be retorqued-- The steel shim material does not compress, That is wht the GM factory used them for ever.
JOE SHERMAN RACING ENGINES
NEW BEST ET
NEW BEST ET
