New Dart SHP Pro blocks
redsmokin57
Re: New Dart SHP Pro blocks
Post by redsmokin57 »
Carl, got to ask what price this new PRO block comes in at after your cnc does it's business, our dollar is on par so us Aussies are out shopping.
Cheers Steve
Steve Menso
57 chev drag 76 pontiac street 34 chev babbit pounder
CNC BLOCKS
Post by CNC BLOCKS »
redsmokin57 wrote:Carl, got to ask what price this new PRO block comes in at after your cnc does it's business, our dollar is on par so us Aussies are out shopping.
Cheers Steve
Steve
We would line hone to 2.6415
Deburr around main journals, cam plug and freeze plug holes and the bottom of the cylinders.
Deck to your desired deck height.
Bore and plate hone to any size using the gasket and fastener you would be using in the end build.
Size lifter bores to your lifters.
Tap all oil galley holes deeper.
Cleaned ready to assemble.
Should run about 2095.00 dollars
Website is up and running
Machine shop tour
Monthly Specials
lun40119
Post by lun40119 »
Carl, do you know if they are using all 4-bolt caps?
Jake
Team Clueless
Optimize the Compromise
CNC BLOCKS
lun40119 wrote:Carl, do you know if they are using all 4-bolt caps?
They are 4 bolt caps from front to rear and as soon as my order comes in I should have some pics
Machine shop tour
Monthly Specials
CNC BLOCKS
Dart just sent me a pic of the caps and bottom end view of the Pro SHP block if it fits your build contact you local Dart dealer!!!
Machine shop tour
Monthly Specials
CNC BLOCKS
Got my Dart order in and had a chance to look over the Pro Block and so far have been pleased with what I saw and the mains were right in the middle, cam tunnel was right at 2.120 and the lifter bores were on the low side and depending whose lifters you are running they may have to be sized. To those who have asked about the studs on the outter splayed holes they are indeed 7/16 studs. Sonic test was very good!!
NOTE we have been seeing a lot of under size roller lifters lately and anyone who is building an engine should measure all the lifters and size the lifter bores accordingly.
Any one needing a specific picture of this block let me know!!
Machine shop tour
Monthly Specials
