What size carburetor do you run, size engine, use?
Troy Patterson
Post by Troy Patterson »
What size carbs are you running on what displacement and for what type of racing?
Troy Patterson TMPCarbs.net TMP Carbs
rskrause
Re: What size carburetor do you run, size engine, use?
Post by rskrause »
Last carb I ran was an 850 on a .60 over 427 BBC bracket motor. Worked well, might have gone bigger for more hp but the goal was consistency.
67RS502
Post by 67RS502 »
pumpgas 420 sbc
1000 demon
90% street 10% strip
I've been told the card is too big :lol:
(and I tossed around the idea of a dominator)
67 camaro
girly rollers on pumpgas:
62 Nova cruiser
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
Ron Gusack
Post by Ron Gusack »
Drag only 427 standard bore bbc with 1050 holley. Tried 825 Demon and lost about 2 tenths.
The things you see when you ain't got your gun!
dfree383
Post by dfree383 »
432" Boss 429 2x1150 Dominators = Dyno Racing
466" Ford 2x1250 Dominators = Dyno Racing
528" Ford 1x1250 Dominator = Drag Racing
347" Ford 1x750hp 4150 = Drag Racing
af2
Post by af2 »
377" SBC 1050 Holly Dom. Drag only.
GURU is only a name.
Solid LT1
Post by Solid LT1 »
355 cu/in SBC stock LT-1 hi-rise intake with #4777 Holley, milled choke tower, de-burred throttle body, OK heads (230CFM int/190CFM exh) Ultradyne solid roller (243/247@0.050.) Best ET with this combo: 12.28@117MPH at the drags in a Corvette chassis set-up to autocross (1.58 sixty foot time.) I was told 650DP carb was too small but, putting a 750HP on same motor caused 60ft time to die (0.15-0.2 seconds loss on 60ft time) and no matter what I did to accelerator pump tuning it wouldn't ET as well as the 650DP, the 750HP did pick-up 1.5MPH. Throttle response in lower/mid range (2500-3200RPM) was important to me as I run Vette at autocross competitions so 650DP was carb of choice.
New motor 380cu/in SBC Super Victor, AFR 195cc heads, Comp solid roller Holley 750HP Ultra still waiting to get on the dyno. Should run into the 11's with new combo [-o<
SB chevelle
Post by SB chevelle »
sbc 355 9.8 comp 248 at 050 525 lift solid flat ported sportsman 2s perf. rpm 850 aed carb... in a 70 chevelle best time 11.79 at 114 3400lbs
Boz-Race Engines
Post by Boz-Race Engines »
383 sbc
252 @ 050
dart pro 1 215cc
vic jnr
750hp
1 3/4 pipes
98 fuel
3460lb
10.44 @129.6 mph
355 holden
260 @ 050 s f/t
vn iron heads
harrop single plane
750cfm
12+ comp
1 3/4 pipes
98 fuel
3300lb 10.48@ 129mph
tried 950hp but ran faster with 750hp
Last edited by Boz-Race Engines on Tue Aug 10, 2010 10:02 pm, edited 2 times in total.
Its hard to move forward if you have a closed mind,
http://www.davidvizardperformanceseminars.com/
jeff swisher
Post by jeff swisher »
I always liked my 750 carter afb the 9000 series...worked well on many 350's from daily drivers to
my street strip cars...or 2 600 afb's on a tr1yx tunnelram that is 12" tall. if you like to show off ..
all my daily drivers and street strip cars have 180-245 lbs of cranking pressure so carb signal is usually really good
I try to shoot for 200 cranking psi
another good one for a 327 was the 450 mechanical holley some reason that thing just plain worked well
I will run a Q jet before a holley for a street strip car...but when tweaked with a grinder the holley will hold it's own and turn corners way better than the afb's.
I have 2 Holleys i need to make time for
A 1966 corvette 300hp 327 Holley all original and looks pristine for its age, curious as to what kind of performance i can get from her and mpg in my 47 dodge
and a 750 double pumper i cant wait to grind on
dsilva7819
Post by dsilva7819 »
I run a 820 CFM ultra holley on my 306ci small block ford at colorado.
fishman
Post by fishman »
409 ci sbc
13/1 cr
264-272 roller cam 634 lift
super victor intake
1 3/4 headers
afr 210 heads...........shift at 6700 rpm@ 4.57 gears
aed 1050 dominator
1.35 60 foots
6.18 1/8 mile @ 111 mph
9.70 @ 137.62 mph
[IMG]http://i44.photobucket.com/albums/f29/fishman1/S7300198-1.jpg[/IMG]
Boz-Race Engines
fishman wrote:409 ci sbc
13/1 cr
super victor intake
1 3/4 headers
aed 1050 dominator
1.35 60 foots
9.70 @ 137.62 mph
whats the weight of your beast fishman ?
redsmokin57
Post by redsmokin57 »
Carter W1 on 181 cubic inches for stoplight racing in a 1934 chev roadster pickup, oh how I miss that carby, one pump of the accelerator and it would hand crank so much easier than the EFI currently fitted, without fear of kickback and personal injury.
Cheers Steve
Steve Menso
57 chev drag 76 pontiac street 34 chev babbit pounder
Alaskaracer
Post by Alaskaracer »
I'll be running an 1190 King Demon on a 600" BBC. Tuneup not known yet, as motor is still being built, and whether or not carb will stay a 3 circuit or converted to a 2 isn't known yet either. Only thing for sure is that it will be on the motor...............drag only, 250" RED
Mark Goulette
Authorized Amsoil Retailer
