What size carburetor do you run, size engine, use?
Re: What size carburetor do you run, size engine, use?
just jokin around like you do with me mate
Its hard to move forward if you have a closed mind,
http://www.davidvizardperformanceseminars.com/
Bill you have taken my comments way out of context, i dont have a problem with those size carbs at all in that application.MadBill wrote:Wow! What RPM for peak power & torque, and what do those carbs flow? (On second thought, maybe you better not say. If BOZ over in Perth and Troy in California get wind of it, you could be caught in the cross-fire...)RayJE Carburetors wrote:313 ci GM Splayed Patterson Engine just redynoed last week at Pattersons made 853Hp and 493ft-lb with my 1.760vent 2.00 Blade Dominators with billet tops ...
i take it back, hows that?swatson454 wrote:I doubt that I'm the only one thinking this but I'll only speak for myself. Let it go, dude! I'm growing quite sick of your attacks. If you don't like TMP Carbs, it's pretty simple. Don't buy one!Boz-Race Engines wrote:
wow two carbs with nitrous too! all that to do a 11.20! hmmm ok.
Mad Bill i appologise if i upset you. ok now we can all move on
I think I know what "Boz" stands for. Can I buy a vowel?
406 SBC 950HP Drag only
Has gone 10.0 @ 130. 7600 through the traps. @3050lbs
Took some gear out and now runs 10.20-30's @ 7200,
get over it everyone else hasfalcongeorge wrote:I think I know what "Boz" stands for. Can I buy a vowel?
personaly ive found the 950hp to be a dissapointing carb after all the hype when it first came out. alot of people were mislead into thinking it flowed 950cfm. some good marketing strategy there.dragrcr71 wrote:406 SBC 950HP Drag only
Me also. When it was introduced, I was still working from the point of view high velocity - fast air speed was "obviously" the avenue to fast response and good power. I wasn't looking at it from the point of view of cylinder filling, just carburetor optimizationBoz-Race Engines wrote:personaly ive found the 950hp to be a dissapointing carb after all the hype when it first came out. alot of people were mislead into thinking it flowed 950cfm. some good marketing strategy there.dragrcr71 wrote:406 SBC 950HP Drag only
Troy Patterson TMPCarbs.net TMP Carbs
- 427Impaler
- New Member
#7320 1150 dominator, old style. 509 BBC iron heads. 4200 pound Impala running street/strip 1.48 60' and 10.31/131mph et.
- 1966 Mustang, 289, solid flat tappet, Performer RPM, Victor Jr., Victor Jr. modified, street / strip, Performer 750; 1.50' Dia. 900 w/ Holley metering blocks, testing with Weber Power Plates and 1.60" dia. venturi
- 1966 GT-350 Shelby, 289 built to class engine rules for VERA, street / road course, 650 dp; 1.40" 800 Holley w / Holley metering blocks
- 2002 Engine Masters Competition, dyno, 359 cid, 60 mm cam, .850" lift, 256 / 256 ish cam, Pro Topline heads ported running 284 cc intake runners, 2.175" / 1.625" valves, ported Super Victor, 10.5 comp., Lemmons Headers, Dyno use, 1.70" dia. venturi 1100 cfm w/ Weber Power Plates, full 1:1 linkage; Bill Maropulos' best ever Winston Cup 830 carb as determined by Bill's comparison on his dyno against hundreds of other carburetors, the 1.70" dia venturi TMP Carbs' carb out powered it by 7 horsepower across the rpm range - would have performed much better in car
- 1965 Cobra kit, 408 sbf, ported AFR 190s, mech. roller, 256 / 256, .625" on 108 lca, street, strip, road course, 850 Demon, 1.70" dia. venturi 1050 Holley w/ Weber Power Plates, 4 IDA Weber Independent Runner System
- '69 Camaro tube chassis, 468, rect. port 2.30 / 1.88, mech roller, 260 / 260, .650" on 114.5 lca, single plane, 1000 hp shot of nitrous, 850 dp modified by LA area carb shop, 1.60" or 1.65" dia. venturi TMP Carbs w/ pri. Weber Power Plate, Holley metering block on sec.
- '72 Chev. PU, 671 blower, 350 sbc, 650 dp, 750 dp, 1.50" dia. venturi 900 cfm w/ Holley style metering blocks
- 34 Ford Roadster, 351 Windsor, B&M blower, 750 vac. sec., stock then reworkled
- '73 Pantera, 408 Windsor, street / strip / touring, 650 dp, 1.50" dia. venturi 900 Holley w/ Weber Power Plates
- '70 Camaro, 468 bbc, rect. port, mechanical roller, Brodix intake, 850 dp modified, 1.65" dia. venturi 1025 Holley w/ Weber Power Plates
- '65 Mustang, 331, hyd. roller specs (?), AFR heads, street, 650 dp; 1.50" dia. venturi 900 w / Weber Power Plates
... and so on...
Troy Patterson TMPCarbs TMP Carbs
... and so on...
Currently what has run best on my 496 high compression bracket race engine is a 1250 Dominator on Methanol. I build and sell them. They flow about 1450 dry on the bench I use. I know, 1250 should be too big for a 496. So the "experts" say. LOL.
- New Member
well my dad ran a 950 with annular boosters on a 302 and it ran great
