Digital Valve Lash Measuring Tool
Postby MadBill » Sat Jul 24, 2010 8:58 pm
Help! Someone recently (2-3 days) posted a pic/reference to digital tool (sort of like the old P&G Valve Gapper) as per title. I though it was from "Precision Instruments" or some such. I'm having zero luck with the Search function since the site revamp and can find nothing about it.
Thanx in advance.
"There's no product that can't be made cheaper and worse."
Re: Digital Valve Lash Measuring Tool
Postby MadBill » Sat Jul 24, 2010 9:32 pm
OK, found it! (In Harold Bettes' new Flow Measurement book): Precision Measurement Supply. Looks to me like it could expedite a new method of checking lash: Rotate the engine slowly through the valve seated range, wiggling the rocker arm up and down as you go. The max gauge reading is the lash; no worrying if you're fully on the base circle of if it has runout.
Postby mustangmike68 » Sat Jul 24, 2010 11:19 pm
MadBill wrote:OK, found it! (In Harold Bettes' new Flow Measurement book): Precision Measurement Supply. Looks to me like it could expedite a new method of checking lash: Rotate the engine slowly through the valve seated range, wiggling the rocker arm up and down as you go. The max gauge reading is the lash; no worrying if you're fully on the base circle of if it has runout.
I looked on their web site and am not seeing it. Do you have a link for the tool?
mustangmike68
Postby jsgarage » Sun Jul 25, 2010 1:46 am
Bill, did you ever hear the story about the P&G gapper when the inventor took it to Iskendarien and demanded he try it? What he really wanted was an official endorsement. Ol' Ed told his machinist to set the valves carefully per the P&G directions, on an unblown Chrysler drag engine that happened to be on the pump. They did a dyno run & logged the results. Then Ed said, "now, set the valves quick and sloppy like we were at the track & you only had a few minutes between rounds" As you may have guessed, the second dyno run showed a few % GAIN in power. The P&G guy left shaking his head. Point is, sometimes real precision settings mean less than getting a combination that works for your machine. I wouldn't spend extra for a microprocessor to tell me if a motor was lashed right, personally. I'd set it, run it and if it needs a tweek, I accept that. Engines are female, I'm convinced!
jsgarage
Postby SchmidtMotorWorks » Sun Jul 25, 2010 2:27 am
I think it would be a nice tool to have.
Nice to check base circle run out with the other pushrods installed as compared to without to see how much your cam moves from spring force.
http://www.schmidtmotorworks.com CamFlowRPM software, CAD CAM CAE CFD, CNC Machining.
SchmidtMotorWorks
Postby MadBill » Sun Jul 25, 2010 7:38 am
If I was Ed, I'd have wanted to use the valve gapper to determine exactly what lash resulted at each location from the quick 'n dirty adjustment, since it was obviously better than the spec setting... :-k
Postby NTSOS » Sun Jul 25, 2010 9:13 am
Is this the lash tool yall are talking about, or is there an electronic version available?
http://www.precisionmeasure.com/valve4.htm
Thanks!
John
I used to be a dyslexic-agnostic-insomniac but I got tired of lying awake in bed at night wondering if there really was a dog.
NTSOS
Postby MadBill » Sun Jul 25, 2010 9:54 am
That's the one. I misremembered that it was dial Vs. digital when I posted the thread. (and FWIW, it is essentially identical to the old P&G device)
Postby MrBo » Sun Jul 25, 2010 5:06 pm
I was shown once that you can really narrow your window of feeler gauge “feel” by how you hold it.
You hold it by the sides, or the way it would cut your fingers if it was thin enough. It magically becomes a better gauge for gauging size.
Think paper cut and it will be clearer.
I can’t see the need for such precision though. The water flow and temperature differece in the head would change your efforts, I would think?
Then again, it seems a whole lot of guys seem to think you need to correct small lifter bore variances.
MrBo
Return to Engine Tech
Who is online
Users browsing this forum: F-BIRD'88, Jthistle4, LJW, SKeown, vannik, WeingartnerRacing and 30 guests
