How Much Twist? Place Yer Bets...
What's your guess?
Poll ended at Sat Feb 04, 2006 7:47 pm
<1/2 deg
7
25%
>1/2<1
6
21%
>1<2
10
36%
>2<4
5
18%
>5
0
No votes
Broke the ^&$#!
0
No votes
Total votes: 28
Post by MadBill »
OK, per my thread on crank twist, I'm now "The guy with the Data"! I locked the flywheel flange and applied 250 lb-ft. to the keyway of a 3.45" standard journal Sonny Bryant SBC (equivalent, per my "...Twist, How Much..." thread, to 550 on the dyno.) How many degrees of twist did I see?
\:D/
(Pix ASAP on previous Twist thread)
Post by MadBill »
Come on you guys! Over 90 views and 9 votes, but not one prepared to go on the record! Maybe I should reveal the answer only by IM to the first 6 to raise their hands... :wink:
SteveS
Post by SteveS »
There is an adadage that goes something like "there was method to madness". And that is what drove my vote for .5 to 1 degree of twist.
bobqzzi
Post by bobqzzi »
MadBill wrote:Come on you guys! Over 90 views and 9 votes, but not one prepared to go on the record! Maybe I should reveal the answer only by IM to the first 6 to raise their hands... :wink:
I voted less than 1/2
SchmidtMotorWorks
Vendor
Post by SchmidtMotorWorks »
I'm guessing 2-4
Engineguy
Post by Engineguy »
1 to 2
[size=150][url]http://www.SportsCarDesigner.com[/url] [color=deeppink].... You [u]want[/u] to design your own car... so go ahead.[/color][b] Sports Car Designer [/b][color=deeppink] is the answer.[/color][/size]
What else can you do with that gift card you got?
highVE
Post by highVE »
Well w/it being a bryant shaft, i would hope it be less the 1 degree, so by bet is .5 - 1full degree max.
Mike Theroux
#84Dave
Post by #84Dave »
If Bill tells us he 'Broke the ^&#%**' , I'll never build another race engine!
Grocerius Maximus
Post by Grocerius Maximus »
250 ft/lb static twist test on a shaft of that structure and diameter will reveal nearly immeasurable twist. <----WAG
Post by MadBill »
Oops! Was supposed to be a PM...
putztastics
Post by putztastics »
Bill please don't get mad.
I voted for >1/2<1 but changed my mind to <1/2 deg
Jesse Lackman
http://www.revsearch.com
Post by MadBill »
Good second guess, Jesse! Guess it's close enough to 24 hours for the poll to reveal that those Bryants are stout pieces: The actual twist was a negligible 0.249 degrees (0.0075" on a 3.45" stroke) Guess we won't be needing any trick sparkers to compensate for that!
Oh well, at least now we know...
Thanks for all the comments and interest guys. :D
Post by MadBill »
Hey! A couple of you guys have voted since I gave the answer! (I suppose you wouldn't have known I did thuogh unless you scrolled all the way down...) Anyway, there were 23 votes before then.
