exhaust flow pipes & radius plates
I'm looking for a guy or company who makes the exhaust flow pipes
for flow testing and also made intake radius plates, .. flow balls and other
useful little flow-bench "do-dads", ..
anyone know who this is???
Curtis
Curtis
Race Flow Development
Give this guy a gander:
http://www.audietech.com/
Bill,
Thanks for the link but I'm not looking for Pitot tubes or electronics, ..
there is or was a guy or company, can't remember the name, ..
but they made these flow pipes and other flow bench stuff, . .. ..
OK, .. so I'm alot of help, ..
Curtis
Curtis
Well, Quadrant Scientific used to, but he imploded several years ago...
The flow balls are pretty easy, you can just weld several sizes of ball bearings to stiff wires.
For the radius plates, I use 5/8" pine; jig saw/file the opening, then go around it with a 1/2 radius router bit. A bit of sanding and a couple of coats of primer and you're done.
For the exhaust, I'm too lazy to even build a bolt-on pipe, I just use a 6" stub of the desired diameter and either move it around until I get the best flow, or outline the correct position of the actual header primary with a Sharpie.
Curtis,
I know that Brzezinski has radius inlets. I don't think they do the exhuast tubes though.
http://www.castheads.com/
Let me know if you need something to build some. My dad owns and exhaust shop and usually has a bunch of old headers laying around. I just cut some up and built my own.
shawn
shawn
No, but I do know several people who would like to "reach out and touch" him...
Apparently there are at least two Bill Andersons living in the region of his former business: http://www.streetperformance.com/?detailedlisting=24
- Dave Koehler
This might be the flow tube guy you were looking for.
http://www.fastpts.com/cgi-bin/hazel-cg ... wtube.html
I think I remember Mondello and a couple of others stock these pieces.
Dave Koehler
www.koehlerinjection.com
Dave Koehler
I thought he went to California.
Depac Dave might know.
If your friend needs help getting that Quadrant Flowbench running there are some pretty sharp guys on the PTS Flowbench Technology Forum.
Greg, (ozrace) has owned one of those benches and might be a help too.
Jesse Lackman
http://www.revsearch.com
