SMI Carbs Sean Murphy Induction any good?
drifter
Post by drifter » Wed Jul 07, 2010 1:25 pm
Has anyone tried a SMI 500 cfm 2 bbl carb from sean murphy? He says they give a money back garnetee if you have another that runs better?
What about Quick fuel's 500 cfm 2 bbl are they any good?
blackford
Re: SMI Carbs Sean Murphy Induction any good?
Post by blackford » Wed Jul 07, 2010 1:37 pm
I have used him twice. He has done a good job both times. The latest carb I got about 4 years ago...a 750 HP for my 331. I had it dyno'd along with air/fuel monitoring and the AF was almost right on. I could have left it alone, but I went ahead and up'd the jets by 1 on primary and secondary. I did have to change the PV from a 4.5 to a 7.5 to fix a off idle stumble. Otherwise good to go.
65 Mustang FB, 331 custom built with 289 H beam rods and 383W piston, 282S cam, AFR 185 Renegades, T5z, 9" 3.89 gears. 430HP@6500
'65 Fastback
JWRE
Post by JWRE » Wed Jul 07, 2010 9:48 pm
I have a couple of customers who use him for q-jets and 4150's. Both claim better results than their previous carb builders.
Robbie DeVane
Post by Robbie DeVane » Thu Jul 08, 2010 2:25 am
drifter wrote:Has anyone tried a SMI 500 cfm 2 bbl carb from sean murphy? He says they give a money back garnetee if you have another that runs better?
Hell, I will take that bet any day of the week. What class do you run and what are the rule's for the carburetor?
www.devanecarbs.com
DeVane carburetors are precision assembled and calibrated to YOUR combo. Are you ready for the next level of performance?
drifter
Post by drifter » Thu Jul 08, 2010 11:08 pm
Carb has to be a 4412 gage legal they check the ventuirs & throttle plate size
Robbie DeVane
Post by Robbie DeVane » Thu Jul 08, 2010 11:28 pm
Yep sounds like the same rule's as every other track that run's the 2bbl's. Don't get me wrong, I'm not saying that I'm the best but I do know that my stuff make's real good power. And for somebody to say that they have a money back guarantee, If you have something else that run's better is pretty much saying that they are the best. And I'm sorry I didn't see Dave Braswell's or Mike Laws's name's anywhere.
www.devanecarb.com
