The plugs are Ac Delco 041LY6SA ( # 6 per NGK table).SchmidtMotorWorks wrote:What heat plug are you running?
Thanks
Should improve, yes.BrazilianZ28Camaro wrote:Troy Patterson wrote:Pretty center section there BrazilianZ28Camaro.
You didn't say anything about the Wheaties. Maybe that's an American joke.
Troy Patterson TMPCarbs.net TMP Carbs
Thanks Troy, two days hand polishing the carb...yes,I had time
Car have a 14.5" eletric fan ...I'm concerned with the air flowing above carb...should a good air filter improve it metering and ET on 1/8 mile??
"Wheaties" was / is a brand of breakfast cereal. The TV commercials claimed it was the breakfast of athletic "Champions". So, it sort of became a joke about having energy and so forth.Yeah, I know what "wheat" mean but didn't know about "Wheaties"...so I'm little off about the joke
I'm glad if you can explain it!
Thanks AF2. I think this carb is flowing a little more than 750cfmaf2 wrote:Valve springs or Ignition.
Very nice elbow work on the carb!
http://www.youtube.com/watch?v=mwA0AbaONqs
I need protein to keep me going!
Got my fingers crossed. Do tell!!BrazilianZ28Camaro wrote:Got it!Troy Patterson wrote:
I feed the lil mouse only with Kellog's ! I think I found the misfire cause!
I'll try that.Matt Gruber wrote:a free test for weak ignition is a tighter plug gap.
was .035?
try .025
Not fixed yet Matt...Matt Gruber wrote:fixed yet?
Tight Plug gap is a test for weak ignition.
it is not the cure; it just proves weak ignition, or NOT.
