Cam Selection 468 BBC (Solid Roller)
Postby michigander » Sun Mar 21, 2010 9:16 pm
Currently building a 468 with studded two bolt block, externally balenced ohio crank, eagle h-beams, wiseco 12.6;1 pistons, 325cc dart pro1 heads, weiend team G, 1050 dominator, 700r4 trans 4000stall midwest, with plans of a th400 when this one grenades. This engine is going in a full size chevy truck that will be used for mud boggin and truck pulling it has 4.88 gears and 42" tires for mudding and will be running 33" ish tires for pulling. I'll be happy to answer any additional questions.
Thanks
Jordan
michigander
Re: Cam Selection 468 BBC (Solid Roller)
Postby blwilliams » Sun Mar 21, 2010 11:00 pm
Here is my experience with high torque 468 BBC's
Get a cam with a narrower lobe center (108) Keep the duration below 280* @ .050.
Run as much lift as you can get at the valve.
My favorite is the Crane R280.
Since Crane is no longer in business call your favorite cam grinder and ask for what they have in this area.
Best of luck with your project.
Erson has a cam that is very close to the Crane. I have used both with good results.
Run the cam a bit advanced to take up for chain or belt stretch.
blwilliams
Postby F1Fever » Mon Mar 22, 2010 7:06 am
I was thinking a cam with 265-272 @ 050 on the intake myself.
F1Fever
Postby CamKing » Mon Mar 22, 2010 10:14 am
I'b be much smaller.
I'd go with a 258/258 for this application.
You don't need to carry a lot of top-end power, you need this thing to pull hard from 4,000-6500.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
CamKing
Return to Engine Tech
Who is online
Users browsing this forum: automotive breath, clutchdude, frankthetank, huero, Rizzle, sorcerer, Steve Salesky and 16 guests
