one piece oil pan gasket. SBC.
- New Member
I use a 4 piece and spot glue the cork and corners an the rest of the end seals with 3M.
Then cover it all with white lube. That way when ya got to do a pan in a hurry or don't have a gasket you are good to go back on.Even if ya just don't want to replace the gasket.
You can R&R the pan at least 4-6 times. Just don't over tighten.
1racerdude
1racerdude
LR
