How important is intake valve lift w/street blown motor?
I picked a Comp solid roller lobe that, with the 1.7 ratio on the intake rocker, will yield me a net .630" lift. Duration is gross 242@.050.
With the AFR 235cc heads, should I bother pushing the lift higher with a lobe change? I could go to a Hi-torque .406" lobe that would get me up into the net .672" lift range. With boost, does the intake side lift matter that much? I hate to leave so much of the intake flow capability these heads have on the table.
Thanks,
Jim
Thanks,
Jim
