Reverse port? I don't know what to call it
I'm looking for the term where they have the intake on the original exhaust side, and vice versa. I don't know exactly what it's called, and am having trouble finding any links.
I'm just curious about this, because it seems it would be ideal for a turbo V8.
Thanks again,
Scott
Thanks again,
Scott
Here is one called a reverse intake engine, Scott......
http://photos1.blogger.com/blogger/2761 ... 0_0102.jpg
http://photos1.blogger.com/blogger/2761 ... 0_0105.jpg
Uses a set of 750cc Honda motorcycle carbs on each side and exhausts vertically via individual stacks.
Hope this helps,
Harry
Hope this helps,
Harry
It appears that BMW and GM beat me to the punch.
http://www.nytimes.com/imagepages/2008/ ... popup.html
The new Ford 6.7 diesel has the reverse flow design.
http://www.autoblog.com/2009/08/31/bewa ... 6-7-liter/
Bret
Bret
Pullin' for Christ
If I'm understanding the original post, he's interested in re-tasking the ports more than a "fresh design" that just happens to have the exhaust in the center of the Vee. In other words, I think he wants to take an ordinary, exhaust-on-the-outside cylinder head and CONVERT it so the gas flow is reversed.
I'm betting that port shapes are inherently more efficient with the gas flow in the design direction--but--I could be VERY wrong.
First I ever heard of revering the ports was with a blown Buick Nailhead. Thirty years later, I re-discovered the photo:
Dick Landy built this for George Poteet:
http://flatfire.com/engine.htm
The stock intake port were used for the exhaust,
and new intake ports were welded up.
This is no too uncommon with Ford V8 flat heads,
because the stock exhaust ports are so restrictive.
didn't ford have that in the early 60's called the gurney eagle or the gurney westlake? I do believe that it was just in a 60's fairlane in an issue of hotrod mag. They used a version of the 260 inch small block and it was overhead cam. pretty cool for the era.
1991 mustang 3040 with driver all motor all the time 9.70 @ 138.75 1.31 60' street driven mufflers and real tires, mt 275/60/15 radials with a 950hp holley.
hmm
that looks like it would center alot of heat under the hood,PFC1 wrote:The new Ford 6.7 diesel has the reverse flow design.
Bret
