5.7 vs 6.0 Rods
- Stan Weiss
I have been well over 12/1, and I usually tend towards longer rod combos, mostly because I hate it when my shit blows up. More important in my eyes re: detonation, is 1) good combustion chamber shape/tight quench 2) keeping the incoming charge cool 3) getting the cam timing right 4) gearing 5) I have better pump gas than most of you! Chevron 942xmod wrote:Ive heard (on this forum) of people running near 12:1 on pump gas. Does in fact the long rod play a huge role in this, or is there other "secrets" involved in this. Brad
Some guys say the longer rod is more detonation prone, because the piston moved away from tdc slower, but personally, I dont think this counts for much in the real world, no-where near as much as the stuff mentioned above anyway. But thats just my opinion.
Here is three more pages from '04. I think it all still applies now.
viewtopic.php?t=406&highlight=ratio
Denis
Denis
Trump might screw us
HILLARY WILL SCREW US
- Location: In the Darkness, where Fear and Knowing are one
*sigh*... The point was the geometry of the combo. As I noted above, a similar combo can be built with high end shelf parts, and of course an aftermarket block. I wasn't asking about that specific engine, just the idea.new engine builder wrote:UMMM,I got the point.The Dark Side of Will wrote:Then you *COMPLETELY* missed the point...new engine builder wrote: I stopped reading when they said 400 block.
They want me to shove a HEAVY ROD in a junk 400 block.
How cares about rod ratio when you are putting it into a junk block.
WHY BOTHER!!!!
- Stan Weiss
This pushes the limits of short and long rod to show the difference. The 5" rod (Red Line) is 1.379:1 rod stroke ratio and the 7.5" rod (Yellow Line) is 2.069:1 rod stroke ratioaxegrinder wrote:Here is three more pages from '04. I think it all still applies now.
Denis
But it clearly shows what Jere Stahl was talking about.
StanI. LONG ROD
A. Intake Stroke -- will draw harder on cyl head from 90-o ATDC to BDC.
II. Short Rod
A. Intake Stroke -- Short rod spends less time near TDC and will suck harder on the cyl head from 10-o ATDC to 90-o ATDC the early part of the stroke, but will not suck as hard from 90-o to BDC as a long rod.
The rod ratio argument has been buried long ago. The actual rod length issue continues. Mostly due to my own curiosity, I did some engine simulation calculations for a 5.70" rod vs a 6.0" rod. stoke-90mm, bore-101.4mm, rpm 8000.
While issues such as piston side forces, maximum velocity, crank angle, etc, have been well covered, there is one area that might bear some examination. The combustion pressure at 10deg ATC is the single most important factor in the determination of engine power due to combustion. So how does rod length affect engine factors at 10 degs?
At 8000 rpm, both engines have a mean piston speed of 24.0 m/s.
The short rod (5.7) produces a max piston speed of 39.5 m/s, vs. 39.32 m/s for the long rod. A delta of 0.45%.
At 10 deg (BTC & ATC) the short rod gives a piston speed of 8.57 m/s with a piston acceleration of 4110g. The long rod gives a piston speed of 8.46 m/s with a piston acceleration of 4063g. A delta of 1.3% and 1.15% respectively.
Maximum squish velocity (at 20% SAR and 1.25" clearance) for the short rod is 18.606 m/s (@10.1deg) and for the long rod 18.492 m/s (10.0deg).
A delta of 0.60% and 0.10% respectively.
What does it all mean?
Mean piston speed did not change
Max piston speed was reduced slightly with the long rod.
At 10deg, piston speed was reduced with the long rod.
At 10deg, piston G was reduced with the long rod.
At 10deg, engine squish velocity was reduced with the long rod.
It would seem that the long rod has advantages everywhere but they are very, very small. The area with the greatest sensitivity seems to be at 10 degrees for piston velocity but not for squish.
Since all of the above effects are very small, it would seem that observed performance would be due to other engine factors not related to rod length.
What say ye all?
Those who do not read have no advantage over those who cannot read.
What say ye all?
As far as your first comment, I totally agree, but I never say it, in the interest of avoiding long-winded, meaningless pissing matches with short-rod advocates. I think you can figure out my views on the rest of it.David Redszus wrote:The rod ratio argument has been buried long ago. The actual rod length issue continues. Mostly due to my own curiosity, I did some engine simulation calculations for a 5.70" rod vs a 6.0" rod. stoke-90mm, bore-101.4mm, rpm 8000.
What say ye all?
- BrazilianZ28Camaro
A longer rod weights more , than it need heavier crank counterweights...
This difference is offset by a slight lighter piston?
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
NEW BEST ET
This question came to my mind as well. Perhaps some of the benefit is that the rod is not a purely reciprocating mass but is part rotating/oscillating? Or is the total mass just that much less?BrazilianZ28Camaro wrote:A longer rod weights more , than it need heavier crank counterweights...
Joe
gotta question
would a longer rod , help start the intake charge more effective since by keeping the piston at TDC longer during overlap , the low pressure area created by the exhaust has a smaller cavity to be expanded accross to initiate intake flow ??
