ap72 wrote:If you only want 500hp you can get there with 10psi or less, it becomes VERY dependant o the rest of your engine combo. A box stock 327 will need a lot more than one that has been thuroughly warmed up. You mentioned that imported parts cost a lot- which sucks- but you are not restricted in that manner to local machine work. Find a competent machinist and get your 327 in top notch condition then boost it. A great porting job can do a lot for you, and the exhaust you run can affect boosted power in a BIG way. If you can build a 9:1 327 that puts out 400hp NA then getting 500hp with 10psi should be pretty simple. And a 400hp 327 is not that hard to do- even with mostly stock parts.
It sounds like you listed a lot of good parts but you don't need to be spending all of that money, you don't need half of the parts you listed to hit 500hp, I would instead maybe look at buying a 6-71 in place of your 4-71.
To be honest this post objective is evaluate how would work a rebuild 471 blower on a good engine like a 327 with the parts described...this engine is only a idea...
Can a 471 justify it weight (and the hole in the hood) making good power?
Or a blower like it is more to show than go?
Thanks for reply
